Results 861 to 870 of 1645
June 1st, 2007 05:08 PM #861
sir v6dreamer... im planing to change all the stock speaker of my toyota gli into 4way speaker "pioneer".... is dat good or bad? im open to any advice..
m also planning to buy some subs...
June 1st, 2007 06:03 PM #862
james0207. those are amplified subs in tubes na nabibili sa concorde. tried one before ok naman but not as good as standard. dapat may sub pre out hu mo. a cheap setup and nice sound, lakas din bumayo. just make sure you put the correct size of wires.
June 1st, 2007 10:38 PM #863
sir randell: my HU is sony cdx-gt250s 52wX4...
well gs2 ko tlga setup na bumabayo hehe nd as much as posible not so xpensive na setup n un quality oks...
June 1st, 2007 10:48 PM #864
I'm already feeling that trouble I presume. Busina ko pasumpong-sumpong na, minsan nagana, minsan hindi. If I'd have my alternator rebuilt due to the lack of an aftermarket one, san ko kaya pwede pagawa? Don't know of any shops kasi that offers such.
And re: secondary battery. Di ba di naman sya gagana when the engine is off? So how can it prolong playing the stereo while it is off? Or was I misinformed by our company electrician?
June 2nd, 2007 12:00 AM #865
another question pla sirs... ok ba kng plgayan ko ng 4way speaker un front and un rear? preparation sana sa boom boom sa future.... :D
June 2nd, 2007 12:18 AM #866
Who connects your stereo system?
Your system must connect on the ACC in your early ignition switch on the ACCessory terminal. If your stereo is not working on the ACC switch position when your engine is off then have an car electrical tech. to correct the problem.
Acc is an early ignition that has a ACCessory terminal. The early switch wires were only IGNITION, BATTERY, START. One big reasons to have an ACC terminal was that you put your STEREO on that terminal so that when it was ON it get full battery voltage. The ACC terminal was hot in the IGNITION position as it was switched off in the start position, giving the ACC 12 Volts or 14 Volts.
What is your estimated electrical current that your system draw?
Go back in my previous post how to estimate your current draw and estimate your system current demands.
*JAMES0207:
4 way in the front or rear
2 way in the front or rear....Vice versa, which one is preferable for you.
4 way front and rear is too much high frequency youll going lost a lot of vocal.
- Apr 2007
- 96
June 2nd, 2007 12:43 AM #867wow The Guru is here...
*v6dreamer
Are you a Filo? All info I read from you are great!!! thanks for your Info...
June 2nd, 2007 12:11 PM #870
China urges halt to auto industry's bruising price wars | CNA China urges halt to auto industry's...
China cars
