Originally Posted by
black0men
*poringdrops
tnx. ill hold off muna pag set up until i hear from you about the prices
2 kasi yung blaupunkt na nakita ko one is 6" na
[SIZE=2]2-way Coaxial loud speaker system [/SIZE] [SIZE=2] Diameter 165mm [/SIZE]
[SIZE=2] Max. Power 200 Watts [/SIZE]
[SIZE=2] High sound pressure level 91 dB (2.83 V/m) [/SIZE]
[SIZE=2] Frequency range 50 - 22,000 Hz[/SIZE]
[SIZE=2] Impedance 4 Ohm
[/SIZE]
[SIZE=2][/SIZE]
yung isa 6 1/2"
[SIZE=2]C 165 XL 2-Way component loudspeaker system with 165mm diameter, 120 watts max. power, a frequency range of 40-25 000 Hz and an installation depth of 55.9mm.
alin dyan ang mas ok. yung 6.5 120 watts lang yung 6 is 200 watts max
for the subs cguro nga d na muna ako magpapalagay. kung ok na din naman yung sounds ng ganyang set up baka di na ko mag sa subs
tnx
[/SIZE]
