Quote Originally Posted by black0men View Post
*poringdrops
d naman ako hardcore na sa lsitening. radio usually pampalipas oras. pag d rnb saka pop. sometimes medjo rock ng konti.
gusto ko lang good bass. crystal clear sounds sa loob. ayoko naman ng malakas masyado na takaw pansin na sa mga tao labas ng sasakyan. mostly pampalipas oras lang while nasa trapik.
sedan nga pala paglalagyan ko. cguro at most im willing to shell out 15k for that. kaya na kaya sa 15k yung set up?
tnx
Hi BlackOmen,
PBWY!
Hmmm...
For HU, I suggest you go for Pioneer nalang. At least mas kilala na and packed with features.
DEH-P4850MPH
Features:
WAV file playback
iPodŽ adaptor ready
BMX (Bitmetric qualizer)
EEQ
5-mode preset equalizer
1-mode custom preset equalizer
3-band parametric equalizer
Bass Boost
2-way crossover: HPF/LPF
3-mode selectable loudness
Selectable FIE (Front Image Enhancer)
Rotary Volume
Direct Sub Drive
1 RCA preout: selectable (rear/subwoofer)
OR
DEH-P5850MPH
Features:
Pure blue dot-matrix OEL (Organic EL) display
WAV file playback
iPodŽ adaptor ready
EEQ
EQ-EX
Rotary Volume
Direct Sub Drive
2 RCA preouts: selectable (front + subwoofer / front + non-fading)
level indicator
I'll check on these two unit's price and will let you know.
For the speakers, a pair of 2 way na 6 1/2" (if 6" is the diameter to fit the front panel) seperates. Para mas solid ang tunog. Blaupunkt or JBL are ok for this.
For the subs naman, do you really want it now? Kasi I'll suggest na you go for HU and seps muna then future na idagdag ang subs kasi it will be nice that you spend the money for a good pair of seperates dahil yan yung talagang listening scores. Subs are for support ng lows lang. If your seps are good, it can produce a good low sound na din but of course not the low as low as a sub can do. Pero syempre, the better the seps the better the clarity also. Actually I will suggest more on a 4 channel amplifier (if i recall correctly and if the price didnt change, JBL is at around 6,000) nga e to power your seps as well as your rear speakers para it will be capable to produce sounds to it full capacity.
But if you really want the subs now, try the Blaupunk under the seat active sub or Pioneer's one. The Bazooka on the other hand, I got a feedback naman from a friend of mine. Nung narinig nya, hindi masyadong solid yung tunog. Medyo kalat. Although the bass is there naman.
This is just an opinion, I think if you add 5k more on the budget, you can have a good system with good brands. I will inquire the prices at the shop where I always go to and will let you know the price.
Glad to help and give you a contenting and delightful sound setup.
Hope this helps. Let me know.
Thanks!
