im planning to buy a dls seps and 2 jl audio 8" subs (meron bang available ganito?). any ideas po kung how much ang seps at subs?
anong model ng dls na seps?! basically ang price range nya nasa 5k pataas.. yung jl audio na subs nasa 8k naman..
aces_fan: I heard my friends setup just a while ago, MB Quart 2-way gamit niya, I didn't get the model. Pero ang ganda ng tunog. Pang SQ talaga, I'll post the model ASAP. Bili niya 8800 ata.
mga sir,
tanong ko na rin kung mura sa 5thou yung targa 6.5, 6x9 and stealth 8 sub ang specs sa baba? Ok na ba ito pang sql?
6.5 3 way (X series X653) 6X9 3 way (X series X693) and 8" Stealth 8 amplified sub
thanks.
sir baurtwellXUV,Originally Posted by baurtwellXUV
good day! thanks for the correction. SQ pala. ano po sa tingen ninyo sa last post ko stated below about the pricing of those sets mura na ba ito? any idea?
tanong ko na rin kung mura sa 5thou yung targa 6.5, 6x9 and stealth 8 sub ang specs sa baba? Ok na ba ito pang sq?
6.5 3 way (X series X653) 6X9 3 way (X series X693) and Stealth 8 amplified sub
many thanks.
actually meron SQL category, yung mataas padin na SQ points but pataasan ng db. Kala ko din dati wala (kinda irritating to see ppl post SQL when they meant SQ)...
mga boss chief!!!
just a newbie here.recently, changed my HU to a pioneer single disc player 45X4 then add pioneer speakers,2 6x9s(330 watts) & another pair of 2-way 160watts sa likod po(94 corolla). kaso i just replaced my front speakers w/ type R(300 watts daw). lahat po sa banawe ko lang nabili. just want to solicit your kind thoughts on how i can improve on the sound quality. parang okay naman sya so far pero parang it lacks a little bit of bass
hope you could help me out in my peril![]()
thanks
opolpogi: you forgot to add an amplifier to power those babies up. the 45 x 4 written on your HU isn't accurate... its only the max power produced. Its RMS power rating shoud be around 16-20watts per channel. Kaya kulang yung naririnig mong bass kasi bitin yung speakers mo, thats where the amplifier comes in.
appreciate your kind comments ILuvDetailing
i have an old pioneer amplifier 35X4 panahon pa ata ni mahoma yun. i got it from a friend & i installed it initially. problem was, it was only 2 way & I had to use a Y-connector to have my HU pass thru the amp.eh sa luma nya, the left channel sometimes malfunction so wala minsan sounds from the front speakersi have a question though..where can i get a decent amp(wattage?) for a good price & do i need to add an 8-inch sub for the bass? kelangan na ng kahon nun,ryt? mejo ok na yung tunog but the bass is not that resonant although kaya naman..should i replace my front speakers with seps?
thanks dude
-scirocco-
bro.. in your case. pwede na siguro yun.. 5k for all of that stuff? good na yun for SQ...
-opolpogi-
i think para mas maappreciate mo. try mo magpalit na muna ng seps.. then pwede mo naman opower yun ng v12 na amp na 5 channel. that can power the seps and he subs as well... if your on a tight budget...
Mga sir patulong naman. Ano suggest niyo for 35 max ang 40k na budget.
Gusto ko sana HU Alpine CDA 9833 or 35. Mga how much ito?
Tapos gusto ko na sub Kicker na S12L7 kahit 2nd hand lang.
Anong amp na mura na kaya i power mga to? Tnx. Kasya ba yun budget?
Car pala is Optra
Gusto ko lang add ng madaming bass.
sir baurtwellxuv,
question though, pwede po pa-detail ng wattage/brand n cost for the seps and the amplifier?yung enough na po for a better sound quality.. san po kaya in banawe would you recommend for the installation.
thanks
secondly, what is a crossover for po?do you need it po ba for speakers with different power ratings? thanks![]()
glntVR: Skip the HU, get a good set Seps, Subwoofers and amplifier. Remember Di nangagaling sa HU yung power. 40K is more the enough for a good setup.
opolpogi: Crossover - Seperates the frequencies so that the component speakers get the proper signal ex. highs and mids for the separates, lows for the subwoofer
Dapat talaga skip ko na yung palit ng HU pero problem ko is ang arte ng HU ko ngayon mga CDs ko na iba ayaw iplay. Ganda na naman ng stock speakers eh. I think gaganda pa ng onti ng sound pag palit ng HU so skip ko na muna yung seps. Next time na lang. Bass lang kasi talaga gusto ko add. Lots of bass.
Problem din pala is hindi ko alam kung pwede ba lagyan ng subs seps and amp yung HU ko ngayon. Thank You sir ILuvDetailing sa suggestion.
Blaupunkt na stock ng Optra. With 5 disc changer siya. Bali parang 2 din. Yung Upper din yung HU tapos sa lower din andun yung slots ng discs
wow mahirap nga malaman kung me RCA out yan(3pcs). for your budget i think pwde ka magpalit ng HU and at the same time magandang setup. have you visited www.kac.com?
