Results 461 to 470 of 1645
May 5th, 2005 06:04 PM #461
question lang po. anu po purpose ng seps? iniisip ko kasi kung ako lang b na hindi na magpakabit ng seps, at subs lang ilalagay ko. stock na lahat.
May 5th, 2005 06:09 PM #462
-aces_fan-
actually ok lang yan. pero for listening pleasure kasi kung magpapalit ka. mas malinaw sya... yung mga drum beats maririnig mo ng mas malinaw...
May 5th, 2005 06:22 PM #464ah... e ang mga rear speakers po? ok lang din ba na stock yun?
May 5th, 2005 10:24 PM #465
aces_fan: I actually started with stock speakers and a sub... Then separates a bit later to replace the fronts with separates. I disconnected the rear speakers. You can actually live without rearfills. Pero kung trip mong meron pa ring naririnig mula sa likod, ok na rin to have coaxials.
Tsikot Member Rank 4
- Feb 2004
- 1,704
May 6th, 2005 02:29 PM #466for a beginning system, i would suggest you get a 4channel amp with built in crossovers, and get a 10 inch sub.
use the front two channels to power your stock front speakers with your crossover set at about 70 or 80 hz. they connect your sub to the bridged rear channels of your amp with your crosoover set to 80hz or 70 hz and down. this will be sufficient. when you have money again, replace your front speakers with separates. when you have more money, you can invest in a dedicated subwoofer amp and another 10 inch sub, para pair na.
dahan dahan lang. just make sure that the pieces you purchase can be integrated in your future system.
May 21st, 2005 11:00 PM #468
curious lang....i dont know much about sound set-ups, how do you connect a single sub to a 2 channel amp???m parang series ba (Left(-) to right(+), then right(-) and left(+) to subs)
- May 2005
- 82
May 22nd, 2005 05:50 AM #469ok ba yung seps na JBL??
tsaka meron bang coax speakers na bilog? usually kasy 6x9 nakikita ko eh..
tia!
May 22nd, 2005 08:07 AM #470
Originally Posted by trup
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
