Results 121 to 130 of 1645
August 22nd, 2004 03:17 PM #121Originally posted by ssaloon
Mach2audio 09178476259 (Pasig)
Dbaudio 09178126620 (Mandaluyong)
Intenz 09166464030/ 02-7316479 (Banawe)
Mickey's Autosound 09175299309 (Pasig)
Tsikot Member Rank 4
- Feb 2004
- 1,704
August 23rd, 2004 10:01 AM #122in my experience, as long as you get a decent pair of separates and don't feed it more power than what it can take, then it will sound better than stock. especially in the future when you add a high pass crossover, then you crank up the volume.
personally, if you don't have the cash and you don't intend to compete, don't buy the P12,000 and above separates, sayang lang.
you can get good separates from 5 to 8 thousand and it will be much better than stock. just remember that your stock speakers probably cost P1500 pesos lang maximum na yun.
SQ is very subjective kasi. my benchmark is clarity and lack of distortion. that is why my priorities are a decent set of separates. a sub and amps that can drive them with built in crossovers. for me, that is enough na, if you do not intend to compete or if you don't want to show off in the parking lot
andy
August 23rd, 2004 11:41 AM #123Originally posted by luckytruck
.... for me, that is enough na, if you do not intend to compete or if you don't want to show off in the parking lot
thanks. i definitely do NOT want to show off in the parking lot. i don't even like cranking the volume in my stereo. hahahaha!
i just want the stereo system in my car to sound good. na-spoil na yata ako with my simple HT set up at home. and i think it would be unacceptable to spend more on my car speakers than on the speakers in my HT set up. so OK na siguro yung mga 5k-8k range.
i went to Autosport in megamall yesterday, and their JBL GTO series starts at P4,120.00. Maghahanap na lang ako ng other brands in the same price range.
- Feb 2004
- 1,704
August 23rd, 2004 12:32 PM #124pare, if you don't cranking up your car, this is what i suggest.
1) decent pair of 2 or 3 ways separates: max 8,000
2) 4 channel amp with built in crossovers. minimum of 4 x 50 watts with bridgeable rear channels.: max 12,000
3) decent 10 or 12 inch sub: max 5,000
total cost will be 25,000 plus 5,000 install and wires. okay ka na.
ito rin ang plano ko. i have had big ssems before: over 1800 watts rms, pero nagsawa na rin ako. balik lang ako small but clear system.
andy
August 23rd, 2004 01:52 PM #125
for beginners? In my case (old SUV) adding a powered sub-woofer would do. medyo bitin kasi bass pag stock set-up. pero ako lang ito ;)
August 23rd, 2004 05:01 PM #127
teka may question ako.... may nakagamit na ba sa inyo nung JBL na bazooka? the one that they sell in Autosport in Megamall? mukhang maganda naman eh.
- Feb 2004
- 1,704
August 23rd, 2004 05:15 PM #129i've never tried powered subs, but the one's i've heard have been disappointing.
targa 2 way separates and targa sub and a 4 channel amp. di aabot ng 15,000 yan, including install.
andy
August 26th, 2004 03:03 PM #130Originally posted by luckytruck
andy
ok lang ba na seps lang muna dagdag ko? i'm leaning towards JBL GTO (4k) or DLS (nasa 6.5k range). i wish i could afford the seps and amp thing, pero nasa 10-15k na yun. di kaya. i don't think i even want a sub, depende siguro how the whole thing sounds.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
