Results 1,121 to 1,130 of 1645
- Jan 2008
- 4
January 14th, 2008 09:26 AM #1121hammerdin where exactly shop mo papa install lang ako, ihave a pioneer HU, 2pcs alpine 6x9s, 2pcs 12inch alpine subs w/o box and a rockford amps.
what is a seperator do i really need it?
habol ko SPL set up, hyundai grace ang car ko w? stock alternator, do i have to upgrade it w? higher amps?
thanks xenxia na bago lang po ako
January 14th, 2008 11:49 AM #1122
Want SPL. Dont bite more than you could chew. Its good to know that you are concern about your alternator could produce. First, you must estimate your current demand in that case you will find out if your car can handle the demands of a multi-amp system(SPL). Once you find out of how much electrical to power up a big pound bass then you will have your thought before you go beyond drastic change.
January 15th, 2008 09:48 AM #1123
wala po ako shop. newbie lang po ako sa hobby na to and im still learning. anyway, suggest ko lang, if you want SPL setup, kelangan mo talaga ng box para sa subs mo. slot port kung medyo budgeted and snailshell naman kung kaya. sell your 6x9s you wont need it. retain your RF amp then get a good pair of seps. try mo 1 x 12" na sub setup. kaya na siguro yan ng 1 12inch.
January 16th, 2008 12:17 AM #1124
was finally able to have my car fixed at Araneta Car Accessories c/o Jeff Tan... SQ lang ang pinagawa ko pero may konting bayo... here's what he quoted for my 15K budget...
Pioneer DEH-2950MP
JBL CS60.4 Amplifier
Targa X Series Separates
Targa Slim Subwoofer w/ box
wires + labor
16,100Php total...
may quote din sya na 13K+ lang pero hindi JBL yung Amplifier...
for me, ok na yung tunog nya.. two-thumbs-up kay Jeff Tan! heehee.. :D
January 16th, 2008 05:34 PM #1125
Ilang inch yung slim na subwoofer bro? is this sealed na parang squarish?
January 17th, 2008 12:38 AM #1127
- Jan 2008
- 4
January 17th, 2008 09:27 AM #1128thanx, i already change my alternator to 11o amps, and have a 2nd rockford coming from the states
- Jan 2008
- 4
January 17th, 2008 09:31 AM #1129thanx for the advise, xenxia na ta nga lang po na tanong, what is snail shell? ano replacement ko sa 6x9? para sa kalansing and last what r seps? inuulit ko po, xenxia na tan ga lang po
January 17th, 2008 03:04 PM #1130
dongster - separates are yung speaker na naka - "separate" yung tweeter sa speaker. yung mga nakikita mo na maliit na speaker na nakasikit either sa dashboard or dun sa side mirror na joystick.
better if you use seps to be able to hear the loud frequencies better, either gusto mo na sa paanan mo sya manggagaling if you buy the 3-ways
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
