Results 11 to 16 of 16
- Jul 2009
- 2,618
February 12th, 2023 06:11 PM #11kung e46 at the age of the car mag expect ka na may mga maintenance items ka malamang sa sigurado. with small displacement bnw's check that the oil has been changed often. even if condition based service started with the e90 prone sa sludge if kulang sa oil change. tingnan mo ilalim ng oil cap. check also plastic parts lalo na sa radiator at its age dapat napalitan na for your peace of mind.
yung gauge cluster mo kun pundi ang pixels alam ko pwede ka mag surplus. sa ibang bansa na re repair nila yan di ko alam kung mayroon sa atin. if broken ang odometer you can double check that with a obd scanner. mileage on the dash are taken from the wheels mayroon seperate mileage counter din sa body control module taken from the transmission. they will not match 100% pero they should be close.
ayaw mo ng straight-6 na bmw? after all forte nila yun noon dun sila sumikat?
February 12th, 2023 06:53 PM #12
Not just these. Generally, never expect euros to age as well as nippons. Issues you've never heard of will happen & the common ones, sooner. Headliners will sag. Fuel pumps, pressure regulators, thermostats, rubber components, gaskets/seals seem engineered to last just beyond warranty. Electronics & diagnostics are mostly proprietary, designed for dealership dependence. And, they're more complex to work on. To access everything under the engine bay, most have to be put on service mode where the front bumper & frame gotta be off. They're DIYable....but not as simple as nippons of the same age.
Sent from my SM-S901E using Tsikot Forums mobile app
February 12th, 2023 11:12 PM #14
February 12th, 2023 11:56 PM #15
But MG just can't be anymore[emoji2957]
- Dec 2019
- 2,072
February 13th, 2023 09:08 AM #16
Puwede siguro gapang ang wire sa space ng rear hatch lifter/struts papunta sa rear bumper, tapos...
