Results 11 to 20 of 20
- Jul 2009
- 2,618
February 12th, 2023 06:11 PM #11kung e46 at the age of the car mag expect ka na may mga maintenance items ka malamang sa sigurado. with small displacement bnw's check that the oil has been changed often. even if condition based service started with the e90 prone sa sludge if kulang sa oil change. tingnan mo ilalim ng oil cap. check also plastic parts lalo na sa radiator at its age dapat napalitan na for your peace of mind.
yung gauge cluster mo kun pundi ang pixels alam ko pwede ka mag surplus. sa ibang bansa na re repair nila yan di ko alam kung mayroon sa atin. if broken ang odometer you can double check that with a obd scanner. mileage on the dash are taken from the wheels mayroon seperate mileage counter din sa body control module taken from the transmission. they will not match 100% pero they should be close.
ayaw mo ng straight-6 na bmw? after all forte nila yun noon dun sila sumikat?
February 12th, 2023 06:53 PM #12
Not just these. Generally, never expect euros to age as well as nippons. Issues you've never heard of will happen & the common ones, sooner. Headliners will sag. Fuel pumps, pressure regulators, thermostats, rubber components, gaskets/seals seem engineered to last just beyond warranty. Electronics & diagnostics are mostly proprietary, designed for dealership dependence. And, they're more complex to work on. To access everything under the engine bay, most have to be put on service mode where the front bumper & frame gotta be off. They're DIYable....but not as simple as nippons of the same age.
Sent from my SM-S901E using Tsikot Forums mobile app
February 12th, 2023 11:12 PM #14
February 12th, 2023 11:56 PM #15
But MG just can't be anymore[emoji2957]
- Dec 2019
- 2,073
February 13th, 2023 09:08 AM #16
- Aug 2024
- 9
December 2nd, 2024 04:08 PM #17"Between the two, the E46 318i with the M43 engine is generally more reliable and has better parts availability. The 316i's N40 engine is known for being less durable and more maintenance-intensive. Fuel economy differences are minimal, but the M43's proven reliability makes it a safer choice overall."
- Jan 2025
- 2
January 18th, 2025 07:41 PM #18BMW 318i G20 problem
Hey all, kinda stuck and dunno what to do. Got myself a new G20 in Aug 2024 and it's making this howling sound when the car is slowing down or even stopped. Look at the videos.
Proton Drive
Proton Drive
What was done:
Went in 3 times to dealer. Took out the brakes and wheels - no issue found.
Suspected AC expansion valve - replaced the valve, top-up refrigerant
None of those help. Anyone experienced this? Heard of this?
The dealership has no idea what's wrong ....
January 21st, 2025 04:22 AM #19
- Jan 2025
- 2
January 21st, 2025 08:33 PM #20
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
