Results 21 to 30 of 248
Thread: Avanza Headlight Upgrade
December 22nd, 2008, 05:07 AM #21
Re: Avanza Headlight Upgrade
very nice info, regarding the camera. basta naka automatic mode, the camera will always balance the lighting so that the image will always look "normal". so dapat naka manual yan with same iso settings before and after. thanks!
December 22nd, 2008, 11:53 AM #22
December 25th, 2008, 03:23 AM #23
just had my headlight replacement to philips xtreme ok naman. sa perfedt dirdle din ako nagpapalit kagaya ni qwerty 1300 kuha ko.
December 25th, 2008, 12:29 PM #24
- Oct 2008
- 380
December 25th, 2008, 11:36 PM #25
December 26th, 2008, 11:18 AM #26
- Oct 2008
- 380
February 9th, 2009, 01:24 PM #27
- Nov 2008
- 55
Hello sir,
If mas brighter po Philips X-treme Power H4, ibig sabihin po, mas maiinit yung nilalabas nyang heat. Kung magkaganon man, possible po na matunaw or masunog unti-unti yung headlight cover nya kasi, plastic lang po yun. Experience ko po sa unang car ko (TYT 2001 Gli lovelife), when I changed to a brighter light, kumupas yung headlight ko. As in nangitim po.
Baka ganito po ang mangyari after sometime.
Yung sabi ng kakilala ko from TYT, the headlight cover is designed to reach a certain temp coming from the bulb. Excess heat can cause burning and blackening of the headlight cover causing poor lighting effect.
rgds,
rastom
February 9th, 2009, 06:44 PM #28
February 13th, 2009, 04:43 PM #29
nagpalit na din ako ng bulb, euroline h4 pure yellow.. kinuha ko lang sa corolla ko.. try lang kung anong itsura.. malakas din.. kakasilaw kasi dilaw.. hehhee
February 17th, 2009, 01:01 PM #30
Hello mga Sir,
Nasaan banda yung Autosport sa Megamall?
I am happy for you. We had a very bad experience with VW Philippines. We will avoid getting from...
China cars
