Dito natin pag usapan tungkol sa pag upgrade nang headlights natin..
eto yung pics nang stock natin..
sa wakas.. nakabili na din ako nung philips xtreme.. got it from perfect circle for Php1,300.00... libre kabit na din.. took the guy less than 5 minutes..
mas maliwanag talaga sya.. i'll post pics for comparison tomorrow..
Here are the before and after pics.. yung nasa left yung stock natin.. yung sa right yung Philips X-Treme.. problema ko lang yung high beam nung Philips x-treme.. hindi na kaya nung camera ko.. kahit anong kuha ko.. hindi nagpapantay eh.. minsan maliwanag yung kaliwa.. minsan yung kanan.. sobrang liwanag siguro hindi na nya makuhanan nang ayos..
eto pala yung itsura nang box..
ok na ok yan pre pang biyahe na long throw yang headlight mo![]()
oo nga.. pansin ko ang layo nang bato nung ilaw.. ayus na ayus to pag bumyahe sa SLEX kahit gabi or madaling araw..
sana may mag install din nang Osram Nightbreaker sa avanza para ma compare natin..
bi-xenon projectors has high beam function. a cut-off shield is used to block portion of the light at low-beam. on high beam mode the shield is pull down to expose most of the light. only 1 light source ( hid bulb ) is required for both hi/lo operation.
ganun pala yun, thank you sir! magkano po lahat damage sir?
kung diy install. around 10K . 55watts ballast with additional shroud.
^ sir napansin ko ung fog light mo..naka projector din ba yan?
oo. same projectors as headlight without the additional shroud.
