test
Results 1 to 20 of 248
Thread: Avanza Headlight Upgrade
  1. #1
    Join Date
    Sep 2005
    Default Avanza Headlight Upgrade
    Dito natin pag usapan tungkol sa pag upgrade nang headlights natin..
    eto yung pics nang stock natin..
  2. #2
    Join Date
    Sep 2005
    Default Re: Avanza Headlight Upgrade
    sa wakas.. nakabili na din ako nung philips xtreme.. got it from perfect circle for Php1,300.00... libre kabit na din.. took the guy less than 5 minutes..
    mas maliwanag talaga sya.. i'll post pics for comparison tomorrow..
  3. #3
    Join Date
    Sep 2005
    Here are the before and after pics.. yung nasa left yung stock natin.. yung sa right yung Philips X-Treme.. problema ko lang yung high beam nung Philips x-treme.. hindi na kaya nung camera ko.. kahit anong kuha ko.. hindi nagpapantay eh.. minsan maliwanag yung kaliwa.. minsan yung kanan.. sobrang liwanag siguro hindi na nya makuhanan nang ayos..
  4. #4
    Join Date
    Sep 2005
    eto pala yung itsura nang box..
  5. #5
    Join Date
    May 2008
    ok na ok yan pre pang biyahe na long throw yang headlight mo
  6. #6
    Join Date
    Sep 2005
    oo nga.. pansin ko ang layo nang bato nung ilaw.. ayus na ayus to pag bumyahe sa SLEX kahit gabi or madaling araw..
    sana may mag install din nang Osram Nightbreaker sa avanza para ma compare natin..
  7. #7
    Join Date
    bi-xenon projectors has high beam function. a cut-off shield is used to block portion of the light at low-beam. on high beam mode the shield is pull down to expose most of the light. only 1 light source ( hid bulb ) is required for both hi/lo operation.
  8. #8
    Join Date
    Jan 2009
    ganun pala yun, thank you sir! magkano po lahat damage sir?
  9. #9
    Join Date
    kung diy install. around 10K . 55watts ballast with additional shroud.
  10. #10
    Join Date
    ^ sir napansin ko ung fog light mo..naka projector din ba yan?
  11. #11
    Join Date
    oo. same projectors as headlight without the additional shroud.
  12. #12
    Join Date
    Jan 2009
    Quote Originally Posted by Ginnova View Post
    thanks sir for the info.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
