Results 1 to 8 of 8
April 11th, 2007 11:14 AM #1
last week, while nasa isang resort kami, sa may parking space eh may water sprinkler pala. eh natapat na dun ako naka park, pero nde pa naka on yung sprinkler. nung pauwi na kmi eh nag spray pala ng water kaya ayun daming watermarks sa hood and some parts of the car's body. ang sama pa eh sa sobrang init eh na sun-baked na yata yung marks.
i tried to remove it by using EO cleaner wax. pero nandun pa din eh. kaya kaya to ng clay bar? ano advice on how to remove this? kakainis eh sobrang dami
TIA!
April 11th, 2007 11:22 AM #2
April 11th, 2007 11:58 AM #3
Try mo 3M scratch remover, then follow up with 3M Hand Glaze then Wax to seal the surface. Solved na problem mo.
April 11th, 2007 01:40 PM #4
Don't waste your clay. Wash and rub it lightly with some vinegar. If that doesn't work, you'll probably have to get it worked over with some compound and polish.
April 11th, 2007 02:32 PM #5
if cleaner wax doesn't work, use a polish, or have a professional detailer do it for you since they will have the tools for the job.
April 12th, 2007 04:15 AM #6
Seriously, don't waste your wax. The residue from the sprinkler is most likely the result of hard water. Good luck getting mineral deposits off with claying. You need a mildly acidic solvent (vinegar), or abrasive polishing, if the minerals are stubborn.
Just remember to wax after the vinegar wash, since the vinegar will strip your car of it.
April 12th, 2007 02:22 PM #7
tnx for all the replies!
what brand of polish should i use? ok ba 3M? i will try vinegar this weekend
too bad i just had my car detailed last feb, then this thing happened. wla na ko budget pa detail ulet...
Nakita ko nga din sa brochure na meron, kaso sabi nung service advisor, kapag J DAW auto down lang...
