Results 1 to 10 of 23
- 82
October 30th, 2002 10:41 PM #1guys, what is your recommended tar remover?
can't seem to appreciate a clean shiny car with specks of tar underneath and at the lower sides. is it true that it takes time to totally remove tar from your car even with the tar remover applied?
hope you could help on this? thanks. :wink:
October 31st, 2002 12:49 AM #2
i use paralax... dont know if its safe...
but it does the job well, kahit sa dried waterspots in the hood... tanggal!
- 79
- 237
November 4th, 2002 10:24 AM #5
mel: tar is aspalto... black, gummy dots you see on the side of the car (near the tires) comes from the tar that is poured onto the road during road repairs.
pyongyong... i like using spray-type tar removers like 3M Tar Remover (P169 a can) if there are A LOT of tar sa car (it rhymes!)... but for spot treatment, a thicker type of tar remover will be less messy (like polyglaze tar remover). Diluted kerosene will work as well but it gets quite messy and streaky, kerosene is not a solvent, it will not remove paint.
All tar removers will remove wax instantly, so make sure you re-wax the surface after you use a tar remover.
- 10,620
- 10,620
- 188
November 4th, 2002 12:07 PM #9share ko lang yung gamit kong wax (Authentic from Soft99) kaya niya tanggalin yung tar.
November 4th, 2002 12:19 PM #10
KEROSENE is the best!!!
Ilagay mo lang sa sprayer bottle para di messy gamitin. Just a few sprays and 20 seconds then bingo!!! Magsisimula nang humulas yung aspalto!!! Sundan mo nalang ng basahan plus extra sprays ng kerosene to finish it up!!!
Works really fine with my big L300 Van!!! And cheap too!!!
Pero sabi nga ni theveed, make sure to re-apply you wax after to restore the paint protection!!! :wink:
Try mo din inquire sa FB page: Hotwheels Trading Evangelista - mabilis sumagot ang shop owner
Finding the Best Tire for You
