Page 315 of 392 FirstFirst ... 215265305311312313314315316317318319325365 ... LastLast
Results 6,281 to 6,300 of 7833
    Apr 2012
    #6281
    Quote Originally Posted by Claud View Post
    Mga Master I just got my car coated. Anong safe na QD for Coated cars? And anong shampoo din?
    I've been using microtex shampoo and Nanosliq for maintenance.
    Sent from my SM-N9208 using Tsikot Forums mobile app
    was the coating done in a shop? if so, you should consult the shop who did the coating kung anong compatible sa type ng coating nila. dapat kasama yan sa tinanong mo or inexplain sayo after mo nagpa-coating. if DIY, ask the distributor of the product
    Jun 2017
    #6282
    Yep I tried asking but they're only advice is just wash it with water then it's already okay.
    I tried searching in other forums seems the safest is carpro reset. Would love to know if there is any product is available locally.
    Mar 2004
    #6283
    Some coatings require you not to shampoo for a certain period ...
    Apr 2012
    #6284
    if they advised to use water lang then why not follow. baka in the process of using shampoo and qd eh magdegrade durability at umiksi protection life ng coating sayang naman. saka if i understood, kaya nagpa-pacoating eh to get rid of the time consuming car washing, wax application o periodic paint correction/detailing. i wonder tuloy why yung iba na nagpacoating still wanted to do pa yung usual wash & wax when in fact dapat hapi na sila sa glass like shine ng coating
    Jun 2017
    #6285
    Yep I'm concerned with the durability of the coat that's why I'm asking if there is any safe shampoo and QD for a coated car.
    I've read some article na proper maintenance is still needed to prolong the life of the coat.
    Hindi naman porket coated na yung car wala na gagawin or no maintenance na. ☺
    this is my first car so I'm asking for advice sa mga expert sa coating. ☺
    Jun 2017
    #6286
    So far base sa mga readings ko I haven't seen any advise na water lang ang ang gagamitin for Coated cars. ☺
    Oct 2015
    #6287
    Ordinary car shampoos will do. QD for in-between washes and droppings.
    Nothing wrong if you apply wax over coating, it is just kinda redundant. Plus I don't think wax will last long on cera or glass coated surfaces due to the hydrophobic or repellant nature of the coating.
    Btw, what brand of coating was used on your car? Some brands have boosters or rechargers.
    Disclaimer:
    Am not an expert on the topic. Just my experience with a 1yr coated car. HTH
    #6288
    Ang sabi nung nag-coat sa oto namin tubig lang at soft microfiber. Tama naman siguro yun kasi nga ung coat eh ceramic nga, parang salamin lang na super nipis.
    Ang gawa ko, kung madumi ang car, hugas muna with sponge, hindi madiin. Tapos drying wipe na with soft microfiber, again hindi madiin.
    Mar 2004
    #6289
    Avoid washing car using sponges ...
    Apr 2012
    #6290
    when i'll have a new car and get tired and lazy of frequent washing and perodic detailing, that's when i go coating. for now, i still enjoy the usual regimen of washing, periodic paint correction at pahid-pahid ng wax. tamang OC pa rin saka marami pa ako uubusin na stock ng polishes at boutique carnauba waxes.
    sa mga nakacoating, you can apply any product as you please. just ensure na hindi makadegrade sa durability ng coating else you defeat the purpose of having it coated. may warranty din ba kapag nagpa coat?
    May 2011
    #6291
    Quote Originally Posted by 3GEMS View Post
    Guys yung mothers instant detailer safe ba sa wax or nakakatanngal? Same as QD ba ito?
    Sent from my SM-G930F using Tapatalk
    Anyone?
    Thank you!
    Mar 2017
    #6292
    Anyone?
    Thank you!
    Same as QD
    Apr 2012
    #6293
    Anyone?
    Thank you!
    i think any instant detailer/qd is safe sa wax/sealant. it can even enhance the shine. the only thing na hindi compatible are those cleaners or all in ones which can strip the wax. i use qd when mga alikabok lang or during quick washes at ok pa yung beading ng wax.
    May 2011
    #6294
    Quote Originally Posted by AllenR View Post
    Same as QD
    Thank you!
    Medyo hesitant pa ako gamitin panlinis anlakas kasi mag tanggal ng bird poop, kahit yung nakadikit na contaminant tangal din parang matapang baka pati wax matanggal. Lol
    Ill try it also portion of hood then tignan kung beadings parin after.
    #6296
    I placed measurement lines on the outside surface of my buckets using a marker, 1 line per gallon. I used an empty gallon container to fill the bucket with water, 1 gallon at a time, then marked the level accordingly.
    For the ONR concentrate, I bought a set of measuring cups, although I could also use the ONR bottle cap to measure the concentrate (0.5 oz per capful, IIRC). I also bought some 30ml droppers (actually, they're some sort of turkey baster, I think), which also work for measuring liquids.
    Pwede din syringes, meron sa Mercury Drug.
    Jul 2017
    #6297
    ive plastidipped the chrome part on the front grille, i covered the headlight except the top part cause you need an inch space for the plastidip peel. to my dismay hindi pala coat friendly yung dip sa UV-Coat ng headlight. On chrome and on the body of the car no issues yung dip. except sa headlight lang.
    now it looks something like this.
    ma rerestore pa ba ito? ive use the scratch out of formula 1. binakbak niya yung UV coat. then it created swirl marks sa mismong surface na walang coat. my plan now is to wetsand it with different levels of grit, polish then top it with gloss clear coat with UV protection. im not gonna sand the whole unit just the affected part. For those who have detailing experience i need your advice on this. thanks
    should i wet sand or should i just cover it with those eyelid things?
    PS. i live in the province, walang honda CASA dito sa tacloban. finding the right products will be a challenge also.
    Apr 2012
    #6298
    Oct 2003
    #6299
    *all,
    Anong okay na product to strip old waxes and sealants? Planning to orde chemical guys clean slate sa US as un pa lang alam ko na car shampoo that does that.
    Anyway, over the weekend hiniram ko ung car ng friend namin, clayed, polished and then 2 coats klasse sg and then pure carnauba after.
    Sakto pagbalik ko ng car nya umulan. Haha
    #6300
    ^KAIO gamit ko
"Tamang OC lang" - a newbie's guide to car appearance maintenance
