Originally Posted by
Kitoy22
I understand your dilemma sir, but if you can post pics, It will be easier to visualize. Usually swirls are really not visible from afar, they only show when you put a strong light on it, if this is the case baka light swirls lang. There's a rule in paint correction to use the least aggressive first, if you have both products already, you can try first ultimate polish in a test area then evaluate if your satisfied with results. Then compare this using ultimate compound beside the first test area. Now evaluate which gives you better results.
But i assure you, if your doing this by hand, you will have a hard time decreasing your paint thickness, unless gagamit ka ng liha.
And dont also expect to get rid of all swirls even with ultimate cmpnd by hand, may matitira dyan na mlalalim. Take your time and rest between panels, if you cant finish within the day, wag mo pilitin bro, your arm will not be as effective towards the later areas.
Good luck! And enjoy! Sarap nyan pagkatapos, mas lalo na at black.
