Page 122 of 392 FirstFirst ... 2272112118119120121122123124125126132172222 ... LastLast
Results 2,421 to 2,440 of 7833
    Feb 2014
    #2421
    swirls can be remove by polishing, by hand or by machine. to learn more about it, read detailing articles in autogeek.com or detailed image. if interested, you may want to join pinoydetailing.com
    ok po thanks a lot )
    #2422
    Quick question - I had my car washed yesterday.
    I'm thinking of waxing it today. Do I have to have it washed again or do I just have to dust it off so I can apply wax?
    Posted via Tsikot Mobile App
    This is where QD's comes in. Dusting may not be enough to remove all dust particles.You would not want dust particles being grinded to you paintwork.
    #2423
    Quote Originally Posted by Ginnova View Post
    Actually I have a Microtex QD (forgot the name) but I don't know when to use it. I tried applying it right after I waxed my car but it didn't make a difference..
    #2424
    #2425
    Quote Originally Posted by yourman_2nd View Post
    get the cali/microtex duster. works perfectly sa dust specially after waxing the car. walang swirl marks iniiwan.
    Bought that duster na.. After removing the dust, anong product ang best gamitin? I still see some handprints eh, sabi quick detailer daw, not so sure what brand is the best.. Any suggestions?
    Apr 2012
    #2426
    Quote Originally Posted by llcooljed View Post
    you may want to try optimum car wax, meguiar quik detailer, mother's instant detailer, microtex nanosliq etc...
    Jul 2013
    #2427
    ^^ good suggestions sir monty_GTV. among the list given, IMO, OCW is the most expensive while nanosliq is the cheapest. ONR can also be a good QD if diluted accordingly. :havefun:
    Apr 2012
    #2428
    Quote Originally Posted by LLOY View Post
    nakaubos na rin ako ng 16 oz spray bottle ng OCW. yung mothers naka 2 na yata ako kasi pang lubricant ng clay. yung diluted ONR ginagamit ko lubricant during claying mas tipid.
    Feb 2013
    #2429
    sir, what is claying?
    Apr 2012
    #2430
    Quote Originally Posted by ricciboy View Post
    claying is the 2nd step when you do detailing or paint correction process. the usual steps are washing > claying > polishing > waxing.
    to learn further about claying, you may read,
    Clay Bar Auto Detailing Guide - Detailed Image
    Auto detailing clay, detail clay bar, clay lubricant, Pinnacle Poly Clay, Wolfgang, auto detail clay, meguiar's detailing clay, auto clay bar
    you tube also has a lot of videos about claying...
    Aug 2010
    #2431
    Don't mix up cleaner QDs with wax QDs.
    #2432
    Quote Originally Posted by jhnkvn View Post
    So what would be the best cleaner QD boss? Nalito ako sa mga acronyms na pinagbibigay nila eh..hehe thanks
    Aug 2010
    #2433
    Your best economical cleaner QD will be water. Hahaha.. cleaner QDs is basically water + lubrication lang naman really.
    The easiest to source will probably be Mother's Showtime... or that Eagle1 cleaner QD spray. But it's expensive if you look at the price per liter. If you plan on "investing", a diluted Optimum No Rinse will serve you very well.
    Apr 2014
    #2434
    Good evening sirs... tatanong ko lang if meron na nakapag-try ng "JML Mantis Instant Shine Spray Waterless Cleaner & Gloss ", nakita ko kanina sa Ace Hardware. Ok kaya?
    #2435
    What the best way to remove water marks?
    I was thinking a regular wash & wax from a know detailer would do the trick, but unfortunately hindi pala kaya ito. Need talaga ng detailing specifically to tackle the watermarks. Although I was told na kaunti palang naman by the attendant - padamihin ko daw muna para sulit. However because my Montero is just 1 month old medyo naiinis ako knowing its there. Even the glass may water marks din.
    If its too much trouble to do by at total noob such as myself... Pls recommend a shop I can go.
    Thanks.
    Apr 2012
    #2436
    Quote Originally Posted by joey_ed27 View Post
    Thanks.
    the attendant is wrong the longer you let the watermark linger sa paint mo, later on mag-etched na yan at mas mahirap na tanggalin. have it remove and have a wax or sealant to protect your paint. shop like bigbert's offer a paint protection program you can avail...
    #2437
    Thank you sir Monty_GTV
    Naku po....Sabi ko na nga ba.
    Aug 2010
    #2438
    Although what monty_GTV is correct, I wouldn't worry about month-long watermarks. I'll start worrying kung hindi mo pa pinapatangal in a year tho
    Jul 2011
    #2439
    Tumagal ng one year, ano yun hindi kinarwash ng isang taon?
    I have tip pala mga bro regarding windshield glass. Buy the finest steel wool you can get, preferably 0000 fine, then use it to scrub the outer layer of your windshield. It will be better than claying your windsheild - removes the embedded debris and hard to remove marks and spots. Then wipe it down with a dry microfiber towel. Use windex or invisible glass after.
    Works for me
    Nov 2013
    #2440
    Sirs where do you keep your waxes & QDs? Are the products safe when stored in the trunk? Or iwanan nalang sa garage?
"Tamang OC lang" - a newbie's guide to car appearance maintenance
