Results 1 to 10 of 10
August 3rd, 2003 10:10 PM #1
may tumigas na droplets of cement sa may trunk ng car ko
how do i remove it?
i tried paint thinner and kerosene na.
August 3rd, 2003 10:35 PM #2
wala yata ako alam pangtangal dyan eh. lam mo last month yun kapitbahay namin nag-paint ng bahay, yun ginamit nya na paint yung emulsion. e malakas hangin, yun dale kotse ko dami maliliit na droplets. di ko naman alam na nag-paint sila at tanghali na ko nagicing, tigas na paint. try ko wd40, thinner nila, wala din. only remedy was to sandpaper (#2000 ginamit) and then buff the car with rubbing compound. buti na lang sagot nila, pero manipis na paint ng car ko.
baka ganun din lang solution nyan. tiktikin mo yung cement tapos buff.
August 4th, 2003 10:28 AM #3
yebo,
You should have clayed the car instead of sandpaper n rubbing compound. Di pa naman matagal ang paint so kaya pa ng clay yan.
August 4th, 2003 11:23 AM #4
cement is not as hard to remove as dried on enamel or metal primer... In most cases, cement can be scraped off lightly then removed using an acid like vinegar or diluted HCl...
- Jun 2004
- 185
April 1st, 2005 03:18 PM #6
If distilled vinegar does not work, try to use miratic (muriatic) acid. Dont' worry. I've tried it on an old ride. The acid won't ruin your paint. It will just soften the cement. Make sure that you rinse you car well. Oh, don't let the acid sit for a long time (max. 10 mins).
April 1st, 2005 06:11 PM #7
Clay is pretty much like modelling clay except that it is very sticky compared to modelling clay. It works by pulling the contaminant part by part.
April 1st, 2005 06:16 PM #8Originally Posted by nicolodeon
OT: san ba nakakabili ng distilled vinigar? wala akong mahanap sa Uniwide and sa Robinsons Place. Any suggestions? TIA
April 1st, 2005 08:48 PM #9
a dremel with a polishing wheel will take it off. if its too hard you can use the brass brush attachment. go in slowly though
April 4th, 2005 10:34 AM #10Originally Posted by ILuvDetailing
