Page 14 of 22 FirstFirst ... 4101112131415161718 ... LastLast
Results 261 to 280 of 434
    Jan 2012
    #261
    Planning on buying Kawasaki pressure washer that comes with the foam spray, any feedback? I’m also seeing a lot of Fujihama being used. My budget max is 4-5k
    Apr 2012
    #262
    Quote Originally Posted by carwhacko View Post
    merong mga brand pasok sa budget mo. bought mine nasa 7k+ yata nun, hindi ko na maalala. for home use ok na rin yan, ma-enjoy mo lalo mag-washing. mostly made of plastics nga lang but if maingat ka naman it will last long. you need good supply din ng water. for the foam spray, you need a good foaming shampoo to produce yung makapal na foam. i've tried yung mga common over the counter car shampoos hindi masyado mabula. pero ok lang naman na hindi mabula, mas importante yung lubricity.
    Jan 2012
    #263
    Sige will look it up. Sa Lazada kasi may mga nakita akong Kawasaki may iba hindi na gumagana unit after 2 usage eh tapos bawal na papalitan. Tapos 3 mos lang warranty nung seller. So far yun lang naman nabasa ko but the rest okay reviews nila. Nasa 3600 lang kasi Kawasaki.
    Hindd totoo yan. Jusr Bought one last month. Sobra naman yan ba 2 uses sira na unless sobrang bobo gumagamit.
    Yun mga brands na mabanggit mo pare-pareho lang yan, isa lang gumawa niyan iniba-iba lang yun brands. Pero Same component lahat yan.
    Jan 2012
    #265
    Sige mukang fixated naman na ako sa Kawasaki option eh. Mejo mahal kasi sa Ace Hardware. Or baka kasi mahal lang yung brand na they carry.
    Jul 2013
    #266
    Try searching Facebook marketplace for pressure washers. May Kawasaki din dun. Yun nga ang baka pupuntahan mo pero at least makikita mo yung unit. For some sellers, may physical shop sila so may babalikan ka for warranty.
    Jan 2012
    #267
    Quote Originally Posted by Lew_Alcindor View Post
    I was about to ask kung wala ba sa mga malls? Or sa True Value, Wilcon etc
    #268
    Di na ba matibay yung Bosch?
    This one has a foamer already.
    https://www.lazada.com.ph/products/n...TkSdv&search=1
    Jan 2012
    #269
    I was also eyeing for bosch kaso mejo mahal and wala pa foam cannon kasama
    Mar 2017
    #270
    Anecdotal: mine (AQT 33-11) has been fine for 3 years now, weekly ang gamit. Yung foamer na kasama emits very thin and runny foam kahit pure shampoo ang ilagay. I just bought a cheap foam cannon separately and it works much better, with thick clingy foam. The machine is a quite noisy, hopefully mas tahimik yung mga new models.
    Edit: bought the AQT 33-11 * P3,600 on sale from Lazada. Foam cannon was P900 IIRC
    #271
    The one I posted has one already. But as AllenR has experienced the foam is runny, I'll take a pass as well.
    Quote Originally Posted by AllenR View Post
    Thanks for the feedback bro. What brand is the foam cannon?
    Jan 2012
    #272
    May foam cannon sa foam it philippines kaso ang mahal naman 1950
    Mar 2017
    #273
    A generic China-sourced one from eBay (the bottle says "MJJC").
    What I like about the Bosch machine is that there are extension hoses available. The hoses now allow me to go around the car without repositioning the machine - a great boon for me since it satisfies my laziness hehehe!
    Edit: here's a foam cannon on eBay which is compatible with the Bosch lance: Snow Foam Lance for Skil 76 AR Blue Foamer Two-Time Bosche AQT Black&Decker | eBay
    Jan 2012
    #274
    Check ko nga sa mall yung Bosch Aquatak kasi laking bagay if may extension hoses eh.
    Sakto din yun extension for then kawasaki or whatever generic China brand. Basta lahat ng fittings for Bosch pwede sa kanila.
    Yun B&D and Bosch. Pareho lang components sa mga China brand
    Eh mas tipid kung yun Regular hoss na lang ang habaan kesa doon sa pressure hose, hinde ka na bibili ng pressure hose extension. [emoji4]
    Jan 2008
    #277
    paano naman yung wire? bibile ka pa extension.. tsaka bitbit mo pa yung unit pag ikot sa sasakyan..
    Siguro halos lahat naman ng bahay meron extension wire na pwede magamit. Hinde na kailangan bitbitin yun Unit. Haba na rin ba na ng kasamang pressure hose, either 6, 8 or 10 meters Yaya hinde ko maalala. Mahaba din naman yun wire na kasama
    Mar 2017
    #279
    8-10 meters na hose, ok na sa normal vehicles. Yung Bosch tinipid yung hose, 3m lang kasama nung AQT 33-11 kaya ako napabili ng extension.
    Saka if i would be able to used it for 2 years Yun kawasaki sulit na na rin. Anything longer bonus na yun.
    It's so cheap parang 2.6k or 2.8k lang yun kawasaki.
    The most 3x a week ko nagagamit.
pressure washer brands
