Got aqt 33-11 for 3.5k sa lazada and if you have a voucher it can cost less than 3.5k
Sent from my SM-G610Y using Tapatalk
so any electric pressure washer pwede magpa custom made ng hose mga sir? katulad ng mga binebenta sa lazada
sample electric pressure washer
TBShield Portable Power Pressure Washer JM5 | Lazada PH
KAWASAKI Portable Pressure Washer | Ikaw Na Buy and sell Philippines Free Classified ads
*dovahkiin. gagana yung foam lance sir. basta may correct fittings ka pang B&D or pang bosch. kaso problem naman sa electric pressure washer maikli ang hose and sobrang haba ng spray gun. meron na kaya nakapag modify dito ng maikli ang spray gun then customize mahaba ang pressure hose.
Sir, may nakagamit na ba sanyo ng Kawasaki hpw 302 pressure washer. Tatagal den kaya to or much better kung B&D or Bosch na lang? TIA![]()
hello. may naka try na ba nun snow foam from lazada? is it compatible with nilfisk? tia.
btw, sa mga nag hahanap. may sale po sa Ace pressure washers.
Me ganyan ako pressure washer pinaservice ko cya bgo matapos warranty nya due sa pulsating sound nya. Nagloko cya uli after 5 months due sa oli leak dun sa pump nya iniisip ko kasi me tama na cylinder head nya in which ndi na advisable ipagawa cya coz baka abutin ng 1 to 2k ang pump motor nya kaya kumuha na lang ako ng AR BLue Clean 143 PW. Kagandahan nya nagamit ko pa yung spray gun at hose ni bosch since parehas sila coupling nya kaya ko cya nagustuhan. 1500W ang motor nya at 130bar na cya unlike sa AQT 33-11 which is 1300W lang ang motor nya at 110 bar lang cya.
Yan kawasaki ginagamit ko ngayon. Mas malakas sya kaysa B&D. Modified the following: hose to 10m, trigger gun with various spray nozzles, various connectors/fittings, and foam lance. I purchased above mods from: >>> Pressure Washers and Accessories Philippines - Shopping & Retail - Mandaluyong, Philippines - 5 Reviews - 81 Photos | Facebook
Mine is just the compact B&D (PW1470TD). I bought it on sale 3 years ago at ACE for around P3,600 as far as I can remember. They were offering me the more expensive one Karcher and Bosch. It's more powerful than the B&D, but I told them it's just for washing my car and I don't think I need that much pressure otherwise I might damage something in my car. Even for the B&D, I needed to adjust the nozzle to a wide one (fan pattern), so the pressure is less. Nobody uses the straight all out pressure nozzle setting as it will do some damage.
For the foam bottle that came with it, I don't think it does the job well. So, I bought a foam lance together with the B&D adapter (metal) from Lazada. I used the Meguiars Gold Class Shampoo as the foamer (30ml shampoo : 300ml warm water). Everything performed to my expectation and just like what I viewed from YouTube. I just love the Meguiars car shampoo as it leaves the car with a deep shine.
My only complaint is that the hose is too short. I'm thinking of buying a much longer one so I don't have to move the pressure washer around.
Has anyone tried the JR Kawasaki or Fujima branded pressure washers? Thinking of getting 1 for weekend car washing duties.
Magtatanong po.. Ano po maganda sa dalawa.. Kawasaki pressure washer or black and decker pressure washer? Ty
May alam ba kayo na hindi masyado maingay? kada press ng trigger kasi yung Black and Decker medyo naiingayan kami. O kaya yung tipong continues yung andar niya.
bilhin mo ung 12v-based na pressure washers...marami choices aliexpress check mo na lng mga reviews.
puro self-priming pa mga yun - kahit sa timba or bote pwede humugot ng tubig.
^meron m pla sa shoppe mas mura
https://shopee.ph/12V-Portable-80W-1...6993.804201655
I've been reading the reviews on the Kawasaki and Fujima/Fujiwara pressure washers and it seems like a hit or miss. I do see lots of the Kawasaki and spares to boot so I guess Kawasaki is the way to go.
