so i paid P2244 for this fujima. hope it isn't crap
Mga pressure washer ba dapat sa drum kumukuha ng tubig or pwede naka direkta sa gripo?
if the gripo can easily supply the required flow rate, gripo is ok.
if in doubt, sa drum reservoir.
in our case, our gripo supply is erratic. we connect the pump to a drum reservoir (actually, a jumbo timba!) that has been previously filled up by the gripo.
pag na-ubos ang drum reservoir, "it's coffee break time".
If pressure washer, make sure your water is filtered to avoid water spots or sediments from spewing out towards your car.
If ever it is not indicated, the best way to know it is to test it. You can try to lift the pump at a considerable height then have the suction hose take water in through a pail and not through a faucet.
I doubt a centrifugal pump will be able to have any suction effect. From what I know, a centrifugal pump is not a self priming pump.
