Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 84
    #61
    eibach maganda yun subok na yan
    #62
    I just installed my apex cupkit 1.7" drop all the way.
    #63
    1.8T,
    wow man! that's a neat drop! nice one for the APEX spring and shock combo :D
    conrad,
    I'm not sure how long the stock shocks will last pero if the stock shocks are fluid for sure in a few months baka busted na yung shocks. It also depends on how low the drop is.
    As for bilsteins for the Altis, try e-mailing Auto_xer*yahoo.com
    #64
    FrankDrebin,
    Musta ride feel ng Onsoku springs mo? Ok rin ba? How low is the drop and Where is it made from?
    #65
    yung pinaputol ko yung spring ko na stock eh after 6 months ang dami na sira sa suspension ko including the shocks! :x balak kong palitan yung spring ng lowering springs talaga..... tapos papalitan ko narin yung shocks ko.....
    ano magandang shocks and lowering springs na affordable na tatagal pag naka lowered ka? Meron ba dito sa pinas na may lowering na 1 inch drop lang... Tnx. :D :D :D
    ang laki ng gastos ko kasi galing casa yung shocks na nasira and take note bago yun...... shet bat di ko alam yun!!!!
    #66
    ulolin666,
    The Eibach prokit or the H&R OE Sport will give you a 1" drop.
    #67
    Okay........ ano gas shocks na pde? yung mura lang pero matagal masira at comfortable?:D:D:D
    #68
    I've read in most boards na if your on a budget... better go for the KYB gas shocks. Just make sure na orig yun kase meron iba fake daw. I'm not sure kung paano tumingin ng orig eh.
    #69
    nung nandyan pa ako sa pinas nung 1999, putol yung springs ng 97 glxi, isang taon lang nagpa-repack agad ako ng cv, then next year nung na-iwan yung kotse sa sister ko, nagpapalit sya ng shocks, tapos balik stock ulit sya.
    #70
    ganun nga talaga! nakakasira talaga ng suspension! Gusto ko na nga bumili para maagapan ko pa yung shocks ko eh! San ba pede bumili ng KYB na shocks at magkano kaya yun? :D :D :D
    #71
    ulolin666,
    yung taga HCP na si Judel meron sya kakilala sa banawe sabi nya dun nya na bili KYB shock nya na orig.
    Dude.... join ka na HCP forum! :D
    #72
    Ndi ko naman sya kilala eh...... Magkano kaya yun?:D
    #73
    Ok lang yun. Post ka sa HCP forum so the other Honda boyz can help you
    I think around 1,300-1,500 ata isa nun.
    Bisita ka dito wag ka na mahiya:
    http://www.hondaclub.com.ph/modules.php?op=modload&name=Forums&file=in dex
    :D
    #74
    Tnx...... Supierreman............:D:D:D
    May binebenta sa akin na second hand na Spoon springs daw! :? eh 1inch sa harap eh 1.25 inch ata sa rear ang bagsak. 9T daw eh? Ano masasabi nyo? :? :?
    May shop ba na nagbebenta ng Neuspeed SofSport Lowering Springs - Front Lowering 0.75" Rear Lowering 0.75" ?
    #75
    May tanong lang ako? ano yung coilovers? Parang lowering springs din ba yun? :?:D
    #76
    ulolin666,
    I'm not sure about the spoon pero parang nabasa ko sa HCP forum dati na spoon springs are stiff kase more on sport performance talaga spoon. Baka di kayanin ng stock shocks.
    Meron sa HCP forum nagbebenta dati second hand Neuspeed soft sport around 6t. Check mo Autoline baka meron brand new.
    Coilovers ...the complete coilovers hindi yung conversion lang... grabe mahal yun sobra :shock: Around 50t ata for a decent set. Its a sprin and shock combo wherein the shock has a threaded body para pwede mo adjust ride height.
    Yung conversion kit/ sleeve type itsura nyan yung Ground Control or yung mga matagtag na Taiwan R1 coil over springs.
    #77
    guys what springs do you recommend for a 97 lancer.. is there a brand that has more than 2" drop? Im using whitelines 2" drop right now m not satisfied with the drop.
    #78
    niwrad,
    do you want to go lower or is the drop too low for you?
    In this thread I was choosing among a lot of springs then it came down to Neuspeed or H&Rs.
    Eventually I got the H&R's and so far the ride feel is ok for me. e-mail Auto_xer*yahoo.com and ask him about H&R's for the Lancer.
    #79
    Supierreman,
    i want it to be lower. 2" drop is quite high for me. What other lowering springs can you guyz recommend to have a 1 finger clearance from the fender in all wheels?
    #80
    niwrad,
    lower than 2" ? H&R Race or Neuspeed Yellow.
    If you want a real low drop... try looking for Ground Control Coil over kit. Si Andeyyy meron bent dati pero for Civic yun eh.
    If you plan to lower ,ore than 2" ... you really need an aftermarket shock tapos you need to get camber kits for your Lancer na.
    Another option is try visiting Speedmode... check out the Sheepdog Coil overs or the B+G coilovers available there.
    You can talk to the guy there (i think the owner) he can tell you lots of things about the pros and cons of lowering tapos he can give you options on what would be your preference (either comfort or sport handling)
    meron sya chart dun with the different spring rates
    Visit this shop... very helpful yung guy dun
Lowering Springs... what would you recommend?
