Results 1 to 6 of 6
- Feb 2014
- 2,556
November 1st, 2017 03:08 PM #2
November 1st, 2017 04:05 PM #3
buy also a remote controlled socket. the problem with these small pressure washers is sometimes the pressure relief valves get stuck and when this happens the wand or the hoae will burst. with the remote controlled electric socket you can turn the pump off before you let go off the trigger.
i can't post the link. search mo na lang meron sa lazada and olx, 220v x 2400w remote controlled socket.Last edited by yebo; November 1st, 2017 at 04:13 PM.
November 1st, 2017 05:18 PM #4
personally I wont buy a portable high pressure washer anymore. Naka bili ako dati ng bosch, kalimutan ko na anong model, mga 13k ata bili ko nuon. di nag tagal nasira yung quick connect (plastic fittings) sa gun and hose and yung mga moving parts sa loob ng gun which is mostly plastic din ay di rin tatagal. Reason is pag nag linis ka ng sasakyan (pick-up for me) You tend to move around a lot since ma iksi lang ang hose so sa katagalan yung yung plastic connections ay lumuluwag and will cause a leak.
Mas prefer ko ngayun bumili nung mga katulad sa gingamit sa mga carwash na separate ang motor and pump. Ang ganitong type is available sa mga general merchandise shop ang high pressure hose so pwede ka bumili ng mahabang hose. Advantage din is pag may sira in some parts of the high pressure hose, pwede mo putulin yung part na yun and install another high pressure fitting sa dulo. Available sa mga general merchandise shop ang hydraulic press/crimper for the fittings and they only charge a few bucks for installation. Also you can buy a separate metal spray gun/nozzle for this type of high press washer that would last decades.
November 4th, 2017 06:54 AM #5
Advise ko lang sir sa iyo after using the unit, flush out mo water by air blow from the washer unit with compressed air. This standing water inside the unit will produce scales over time. To do this, aim/insert your compressed air nozzle trigger to the water inlet. Ensure that the pressure washer hose is disconnected from the unit. Isama mo na rin airblow yung hose and washer lance to remove standing water. You may want to check on Pressure Washer and Accessories page sa fb >>> Pressure Washers and Accessories Philippines - Home | Facebook you need some fittings, lances, trigger guns, and hoses.
Sent from my SM-C900F using Tapatalk
- Dec 2018
- 27
April 8th, 2019 05:56 PM #6
It sounds like a potential headache for the unlucky ones that got their units from EV solutions PH...
Hybrids and EV
