must be fun removing scratches with your cerium oxide😅
Gtechniq CSBlack - YouTube
That is kind of hard to quantify even by professional detailing standards, since you have a lot of variables to consider, and I don't think anyone has a controlled experiment to determine the actual length of time that glass coats will outlast sealants. From what detailers have said, if you have a black car, if you have the time, then probably better to get the sealant since black will need regular maintenance vs other colors. Otherwise, if youre short on time, have colors that conceal blemishes better, then probably better to get the glass coating.
Question about glass coating mga sir. Kung tumatagal ang glass coating ng 1 year. So parang same effect lang pag nag apply ako ng collinite wax na kaya tumagal ng 1 year din? If same effect lang nakatipid ako. Naka pag exercise pako sa pag apply ng wax?
Sent from my vivo 1606 using Tsikot Forums mobile app
yes..
but then coating packages include..
1. paint correction of 2-3stages
2. some include interior protection
3. some include glass coating
4. some include wheel protection
5. plastic trim protection
and it lasts 2+ years for the newer formulas.
does collinite have anti static properties?
some waxes soften..and when they do you will feel the ash fall or carbon particulates on your wax...
so called "gaspang"
yes and no.
yes, let say meron ka 2 car, yung isa naka coating and yung isa naka-wax. if you leave them sa garage for a year without using them, well covered and away from contaminants and harsh elements then, probably same and paint condition lang sila after a year.
no, if daily use yung car i'm certain yung glass coating tatagal ng 1 year (or more) kung maayos pag-maintain. yung collinite wax hindihanggang 2-3 washes lang yan re-apply na ulit. at the end of the day, if well prepped yung surface at marunong mag-maintain yung naka-glass coating, mas maganda condition ng paint niya. whereas, yung traditional na nagwa-wax, most likely maraming swirls since panay ang hugas at punas.
btw, wala ako car na naka-coating. but soon, one of my car will be coated...![]()
monty.. before and after 20megapix photos 😅
Pag lumabas ung ni-order namin na suv balak ko din ipa-ceramic coating. Para mas mabilis i-maintain.
Pag coated ang vehicle pwede ba lagyan ng wax and sealant on top?
most shops will advice against it...
