Page 17 of 22 FirstFirst ... 7131415161718192021 ... LastLast
Results 321 to 340 of 680
    Feb 2013
    coat maintenance wash..
    basically a car wash for your coat...
    Do we only get that from the coat installer (Donj)?
    Oct 2003
    I bought some products at Amazon to maintain the glass coat of our car. Carpro has their Reload spray. Gyeon has their Cure spray. I went with Gyeon to try it out.
    Rinse then foam wash using ph neutral shampoo then use the maintenance spray as a drying aid.
    **Also bought Gyeon Wet Coat to try out to our non-coated cars also**
    Sep 2017
    I have a sealant and I have no issues with bird droppings, tar and bugs. These things shouldn't affect the coat if it cured properly. maintenance washes and of course tar/sap/bug removal if necessary...
    Maintenance washes as instructed by Larry of Ammo NYC mean rinse with water then dry with a lubricant. Do you mean the same?
    Quote Originally Posted by MamBad View Post
    if heavily soiled... you still need a waah to soften the dirt..
    either way coat needs maintenance...
    his black Porsche is amazing. tires and custom wheels too 😀
    Oct 2003
    *kinto92
    Ung glass coating ko sa tabi tabi lang haha sa shop ng friend ko. I think pika2rain gamit nya, from japan.
    Product na binili ko sa amazon is Gyeon Cure and Gyeon wetcoat. Gyeon cure is their maintenance spray. Mga once a month to maintain glosiness and hydrophobicity. Should work with other brand's coating as well.
    Gyeon wetcoat naman is for our cars without any coating. Will try it out kung it works as advertised.
    First time I washed the car with coating the other day. Sobrang bilis nga linisin. The water just drops off unless puro flat surfaces. Buhos mode na ako. Hehe.
    Aug 2017
    Quote Originally Posted by zechs View Post
    *kinto92
    Sir is there any suppliers or shop na mabiibilan locally ng gyeon cure. I think it was Lithuania product.
    Sent from my iPhone X using Tapatalk
    Oct 2003
    *montro,
    Not sure kung may local reseller. I dont think Gyeon is Lithuanian though.
    Oct 2003
    ^ found a local distributor/detailer of Gyeon here in the Philippines. Its in the south though, along daang hari road.
    Aug 2017
    *montro,
    Learned gyeon is Korea brand and international distributor is Lithuania.
    Speak with tristan of SC. Gyeon cure 120ml 1k. [emoji3]
    Jul 2017
    ONR experiment findings on the glass coat... I got good results on the No Rinse Ratio. The car is kept clean and the dust is less noticeable. I tried QD ratio on the whole car, the week before. It seems to attract a lot of dust. Pero baka that's not the right use. Also, i parked the car sa open parking ng MOA.
    I'm kinda curious on carpro's ech2o. Has anybody used that on their coats?
    On the ONR No rinse ratio, I used a 1.5L water spray with pump. Yung pang garden. Kasya naman sya for the whole car basta hindi gaano ka dumi. Tapos may sponge ako with to spread the solution and pickup the dirt. Tapos micro fiber towels to dry the car. Hindi ko lang about yung roof. Kelangan ko ng step ladder hahha.
    Sent from my MI NOTE LTE using Tsikot Forums mobile app
    Oct 2017
    Quote Originally Posted by kinto92 View Post
    Sorry out of topic question... is it ok to step on the tires to reach the roof ? I dont have a step ladder so the only way is to step on the roof... i am not that heavy..150lbs hehe
    Sent from my SM-G950F using Tsikot Forums mobile app
    bro some qds do not have anti static properties...
    buffing also intensifies static.. wet vs damp vs dry
    each suv tire(265-60-18) is rated above 1000kg(at max psi,44)
    your weight is an ant vs the tire capacity 😅
    Oct 2017
    Haha thanks master bro... merry christmas!
    Change wipers blades then have the blades coated also.
    Sent from my SM-G610Y using Tapatalk
    Oct 2003
    *ginnova,
    New wipers eh. So i should have the blades coated also sabay doon aa coating ng windshield? Interesting.
    Yes wiper blades need to be coated as well.
Inputs needed: Glass Coating
