Originally Posted by
madkatz
Yes i believe Sapphire Paste will give you better results, As with all Collinite paste waxes you really need to apply it really really thin so it becomes very easy to remove, its not really hard, it would be hard if you apply too thick, so just do it per panel, this is the most easiest and fail safe way to apply collinite paste waxes, and if you notice the wax is a bit hard to remove then you might be applying too thick and then from there pick it up on how thin you should apply, if you're planning on attending the seminar then you could see first hand how they apply it, as they the experience is the best teacher
