Quote Originally Posted by weszt View Post
wow tireblack that can be used on plastics trims, medyo namumuti na din kasi ung ibang plastics sa exterior.... napabayaan na.
yup that's my mistake, i did not work the polish for a long time. waaahhh maybe that's why im not satisfied on the shine n my car? next time ill try the 20 passes. 3-4 settings...hehe
ah ok i thought its better to apply ag srp/m21/ and next gen 2.0 by ROP because you've mentioned that my ROP is way better than a PC when it comes on applying glazes. better to stick on hand application...
how do we properly apply elovo on the windshield? with ease...
1. clean with carshampoo?
2. clay
3. clean again?
4. apply elovo
5. apply carlack 68/diamondite sealant?
and finally how do i remove this stubborn dirt around the emblem... its very hard to remove....
Machine application of glazes is ok since glazes tend to dry really fast but those products you mentioned are not glazes, AG SRP can be applied using machine to give it a little mo pump in correction so you get a better shine but thats just about it, M21 and NXT are both pure waxes unlike AGSRP which has some polishes, M21 and NXT don't have polishes so there's no point to work them using the machine
the kit has a foam included that you use to wipe the windshield clean of waterspots
yup that procedure is correct.
