toothbrush and/or small version nitong nasa pic para sa singit singit ..
sakin kasi di na umaabot sa sobrang dumi kaya cotton buds lang ok na
Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
Takot ako gumamit ng rubbing compound lolz
May tulong kaya degreaser? paint safe ba degreaser?
you can use dishwashing soap as degreaser
wag ka matakot sa rubbing compound, sa gumagamit ka matakot lol
if uncomfortable ka, via hand application mo para di maubos clearcoat
Question lang.
How to maintain piano black finish?
Yung side door pillars is piano black finish po kasi.
Kahit anong ingat, na scratch pa rin.
Galing na ako sa detailing to remove the scratches nito.
Paano to tanggalin hairline scratches niya at ano maganda product to protect piano black materials?
May wax na po, dalawang layers.
turtle wax ice seal n shine improved formula + collinite as a toper.
Nagka scratch parin.
Yung hairline scratch na usually visible sa piano black.
Yung shiny black na wrap, same lang din ba ng piano black material na madaling ma scratch? Im thinking ipa wrap nalang if visible at malalim na talaga yung scracth niya.
The scratch I mean is the hairline scratch that you usually see sa piano black finish, not the major scratch.
Your wife, or girlfriend, of whoever is your passenger, must have a long, sharp, pointy, fingernails!
You might want to consider putting this to protect the piano finish.
You can just cut it. I have intended to put it on the door sill but I've been "lazy" for the last three years that I haven't opened it yet. In fact, I remembered I have that because of this post.
[emoji3]
I think it will be too difficult to apply this as a door cup. I suggest buying it separately. Here's the link but you can find a cheaper one to practice on installing it.
https://shopee.ph/product/21594805/4...8-1620985075.9
Need pala to i cut ng maayos para ma install sa pillar.
Cutting at precise cut is not I am good at.
Better to leave it to professional nalang, will look near my area kayang mag install with correction.
Yupp, sa door cup, naghahanap pa ako ng specific product fit sa car ko.
Just wrap those piano gloss scratch prone trims
Mazda 3 Trim Removal and Carbon Fiber Vinyl Install - YouTube
Bareta na sabon, sureball yan bro, pati sa itim ng hood tanggal
Sent from my Mi A1 using Tsikot Forums mobile app
