Page 113 of 127 FirstFirst ... 1363103109110111112113114115116117123 ... LastLast
Results 2,241 to 2,260 of 2535
    Dec 2014
    #2241
    Anyone used Fast wax before? There's a love-hate review online (amazon) and not sure if they are credible.
    Aug 2012
    #2242
    Quote Originally Posted by crosswind View Post
    Where did you buy this bro?
    Available in OLX or Facebook bro.
    D3 Technologies
    Sent from my D5833 using Tsikot Forums mobile app
    Jul 2011
    #2243
    Quote Originally Posted by red_one View Post
    Black & Decker polisher uses low power motor, has low single speed (orbits per minute), and uses bonnets (cannot use foam pads without modifying the backing plate). You can use them for applying and buffing wax BUT not for paint correction (compounding and polishing) due to low power.
    To compare:
    B&D KP600/KP900 = 60W motor, 1-speed
    B&D KP1200 = 120W motor, 1-speed
    Meguiar's MT300 DA Polisher = 500W motor (High Torque), 6-speed
    Griots Garage 6" DA Polisher = 850W motor, 6-speed
    If wala budget for better brand of DA Polisher, I suggest a drill kit instead. Can use standard velcro foam pads from any brand. Can be used for compounding, removing scratches/watermarks, polishing, waxing, buffing, etc.
    Hi newbie here sa detailing. plan ko sana kumuha ng 1100W 180MM SANDER POLISHER. variable speed nman sya. kahit ba sa pinaka mababa akong speed delikado pa rin gamitin ang rotary? gusto ko kasi talgang matuto gumamit nito eh. thanks
    Aug 2012
    #2244
    For new user, pinakasafe sa paint is DA polisher talaga.
    Ang rotary tool kasi kahit set mo sa lowest speed ay single action pa rin, i.e. it only spins flat.
    Where as yung DA polisher by its name is dual action, i.e. it has orbital motion.
    If gagamit ka nyang rotary tool, you need to practice on some spare car panels. Hanap ka sa junkyard.
    Sent from my D5833 using Tapatalk
    Jul 2016
    #2245
    Hello mga sir.
    Im seeking advise and help about my first car.
    nagkaroon kasi siya ng mga scratches kasi napunasan siya ng pero di napansin na may mga putik ang body.
    Gusto ko sana ipadetail pero gusto ko din sana iDYI detailing. Makakahiram / makabili nman ako ng buffing tool. hindi nga lang DA.
    Ano pa po ba ang kelangan ko malaman / bilhin to start my DYI detailing? Thanks
    Aug 2012
    #2246
    The first thing you should know is how to backread the forum.
    PM me your email address, I will send you some detailing guides. You can start from there.
    Jul 2016
    #2247
    *sir red_one
    yes ser! yun na nga ginagawa ko lately.
    backread sa mga forums / youtube tuts.
    sakit sa ulo isipin ung gasgas haha.
    kahapon nag DYI carwash ako and turtle wax using microtex buffing cloth ata yun.
    medjo nagwala ung mga hairline scratches galling sa putik. tingin ko mag aapear ulet un kapag nawala ung wax. hays
    Pm sent ser! salamat
    Dec 2014
    #2248
    At dahil tag-ulan na talaga. Kailangan ng paint protection 😁😁😁. Pati steelies syempre.
    2 bucket method car wash
    Optimum GPS - Glaze Polish Sealant
    Meguiar's hyper dressing
    Winner ang steelies. Wehehe.
    Jun 2016
    #2249
    Quote Originally Posted by Venerzky Buban View Post
    Nice! Ang kintab! ano po sir gamit nyo sa windows at headlights?
    anyone here used meguiar's white wax? i'm planning to use it on my fd's pearl white mica oem paint job
    Jul 2015
    #2251
    Megs white wax is not too common here, you have a hard time getting feedback from this forum. But you are looking for cleaner wax specific for a light colored paint, it's worth a try, it will definitely amp up the shine, since it contains abrasives found in megs ultimate polish. Just dont rely too much on the protection, durability is not the strength of cleaner waxes, i suggest you follow it up with a more durable wax or sealant.
    Dec 2014
    #2252
    Quote Originally Posted by jmusicalis View Post
    Same din po
    Jun 2016
    #2253
    Hi, anyone of you tried glaz stainz out and stainz guard? how do you apply it? Do i need to shampoo my window first? Thanks in advance
    Aug 2012
    #2254
    Any detailing product needs to be applied on a clean surface. That is standard procedure unless the product is a cleaner itself, e.g. glass cleaner, quick detailer, degreaser, etc.
    Jun 2016
    #2255
    I see. I thought i can already apply stainz out right away without having to clean the windows.
    Thanks sir red!
    Jul 2015
    #2256
    It will work better on clean windows, it is not an aggressive watermark cleaner, you will need to put in some pressure to make it work, if it dries, just spray water and rub it in again until you see your desired results.
    May 2011
    #2257
    Ano pwede pantanggal sa already hardened cement? Medyo matagal ako hindi nakapagcarwash then nakita ko on lower part paglinis ko may matigas na talsik ng cement, hindi na kaya ng gaas. TIA
    Sent from my SM-G920F using Tapatalk
    #2258
    Quote Originally Posted by 3GEMS View Post
    kuko! fingernail. and even then, you might cause some scratch marks... heh heh.
    others say vinegar.
    and the earlier, the better, before the cement hardens.
    May 2011
    #2259
    others say vinegar.
    Hindi na kaya kuko, Doc.. 3 weeks kasi ako hindi nagcarwash. Anbilis naman ng karma..
    Jul 2015
    #2260
    Try mo sir mag clay, pero this will create cloudiness sa paint or swirls, follow it up nlng ng polish.
Detailing Thread [For Newbies][continued 3]
