Results 1,481 to 1,490 of 2535
- Aug 2008
- 965
October 1st, 2013 05:57 PM #1481
October 1st, 2013 09:03 PM #1482
I have not tried XMT and Wolfgang so I cannot comment on them. what I have and using are pinnacle advance swirl remover/finishing polish combo, menzerna fast gloss fg400, power finish pf2500 and super finish sf4000. all have their strengths and best uses in combination with the right pad. the trick is to try first in a small area the least abrasive polish and pad combo, kapag sa isang pasada di nakuha mga gasgas o swirls try mo yung isang pasada pa ulit or till mawala mga swirls. say sa 3 passes nawala then you have a good combo. but that will tell you na 3x mo pasadahan bago mawala ang imperfections, nakakapagod di ba? next try a more aggressive polish, kapag nakuha mo sa isang pasada, well and good, you have the right combo. but don't just jump to a very aggressive polish and pad, baka natanggal mo nga ang mga scratches pero nagka-marring naman yung pain surface mo.
wolfgang glaze? wala rin ako niyan, meron ako poorboys blackhole saka chem guys ez crème. btw, glaze are more of a fillers, they just hide swirls and minor scratches para pag wax mo makintab at makinis. minsan ko lang gamitin kasi nakakatamad na ehkapag nagpolish at finish ka, then sisingit pa yung glaze bago ka mag sealant o wax.
di rin ako familiar sa meguiar pero gusto ko bumili nung m105 ultra cut compound at m205 at ultra finishing polish. standard combo rin yan for polishing at finishing. HTH
- Jan 2010
- 371
- Mar 2010
- 5
October 24th, 2013 01:50 PM #1484Hello mga detailing gurus! Did a lot of backreading and I wanted to do wash>kaio>ksg> 476>ocw tapos ONR/microtex shampoo as daily wash if possible. My car is a new pearl white crv. It will be parked in a closed garage but the area is quite dusty since it is near machines that are used to mix animal feeds.
My planned regiment is:
Kaio+ksg every 3 months
476 every 2 months
ocw every 2 weeks
is this adviceable? Or should I adjust the time frames for application?
Also how much does the klasse twins go for in the phil?
All advice is greatly appreciated! TIA!
- Oct 2012
- 26
October 25th, 2013 02:51 PM #1485Same thing as above but can I add Nanofil in the equation?
Wash > KAIO > Nanofil > KHSG > 915
I really like how Nanofil promises to fill or minor swirls or scratches.
Thanks!
December 14th, 2013 04:03 AM #1486
a while back i thought asking the painter for additional coats of clear is beneficial but to a limit, i didn't know that that limit is a sharp one. 2-3 coats and it's done, no more. else check the technical sheet of the clearcoat.
December 29th, 2013 05:19 PM #1487
Good day mga detailing gurus! Question lang po kung may distributor dito ng Autoglym HD wax? Magkano po kaya yung AG HD Wax Kit nila? Maganda kasi nababasa kong reviews regarding Autoglym HD wax kaya gusto kong i-try. Thanks!
January 15th, 2014 12:06 PM #1488
- Sep 2011
- 241
January 15th, 2014 02:05 PM #1489
Tried the WG 3.0 Sealant and so far after 2 mos its still ok for me. "Glassy" yung effect nya although may layer sa taas na Collinite 915 na "deep gloss" for me yung effect( parang pwede mo ipasok yung kamay mo :twak. The Collinite lasts approx 1 mo. sa kin because lumalabas na yung "glassy" effect nung WG after that. Managed to observe the WG for a couple of days before topping it with Collinie and what I liked about it ,is how it repels water (Oct 2013) while the Collinite "beads" water (mas spherical yung beads nya compared sa Microtex nano gloss, parang gugulong yung tubig :rofl
My regimen last October was clay, compound, polish, sealant then wax. Planning to do a clay then straight to wax by March or April, tignan ko tibay ni Collinite sa summer baka ayaw niya na naka topped lng sya mas ok panu para sa kin yung effect nya sa paint ;)
- Oct 2011
- 35
January 16th, 2014 12:45 PM #1490Anyone here heard of propower mist and wipe detailer? they're selling it dirt cheap sa truvalue. 60 pesos na lang ata for 225 ml. kuha sana ako madami if pede pang lubricate ng clay?
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
