Page 42 of 127 FirstFirst ... 323839404142434445465292 ... LastLast
Results 821 to 840 of 2535
    May 2012
    #821
    Quote Originally Posted by cjv_justice View Post
    kung red po yung car, use the Reflections Spray wax ng Mothers. the FX is much better for silver color shades. believe me... i know. 'learned from the experts here and PD.
    by the way sir, naka bili napo ako kanina ng Mothers FX sa Ace hardware, kukunin ko po dapat ung reflections kaya lang 900+ compare sa 450+ ung FX, pag naubos ung FX, palitan ko nalang po ng Reflections. Thank you sir
    Aug 2008
    #822
    The Mothers line is a good alternative, and less expensive locally than Meguiar's. Again, haven't used it, but I've read good things about the new Mothers California Gold Synthetic Wax - reasonable price, has a nice darkening effect, and some cleaning ability. You can then top it off with your spray wax of choice perhaps at the next wash.
    #823
    Quote Originally Posted by indiej View Post
    None at Tru Value? There's also the Carlack combo that's the same with Klasse, just in case you chance upon them.
    Sorry sir, Tru Value doesn't carry Klasse and Carlack anymore. Thanks anyway.
    Aug 2011
    #824
    Sumakit na ulo ko pag back read. Eto nakuha ko for best results na routine?
    1. Wash car, dry.
    2. Prep paint - depending on the condition of the paint, choose any of the 3 below.
    a. clay (once a year or as needed?)
    b. polish (twice a year or every quarter?)
    c. apply pre-cleaner wax / cleaner wax (once or twice a month?)
    3. Apply Sealant (Glaze?).
    4. Let cure or on the next car wash, apply wax.
    5. On the next washes, apply QD. Depending on the durability of sealant, wax, pwedeng ito lang gawin after washes.
    6. An alternate is spray waxes after washes.
    Yung #2 pwede rin skip kung good condition pa ang paint.
    Aug 2008
    #825
    Quote Originally Posted by vefyjeph View Post
    1. Wash car, dry.
    Looks about right. For polishing, I would stick with doing it annually, at most - you shouldn't need to do it that often if you take care of your paint properly. I do always use a pre-wax cleaner of some sort before applying a new sealant/carnauba wax - just to remove any embedded dirt in the paint, as well any remnants of the old LSP, to ensure that the new product is applied on clean paint.
    May 2012
    #826
    mga master sa detailing ask po mga sir what the best gamitin para quarts brown na monty 3months old at my marka ng na tuyo sa harap sa may hood
    TIA sa mag input
    Jun 2007
    #827
    what are the "correct steps" in a 3step exterior detailing? was canvassing at a carwash, first step daw is 3m rubbing compound. want to verify if this is ok.
    May 2011
    #828
    mga boss, kaya po ba ito ng rubbing compound or kahit anung dent remover wax?
    nakikita ko po ung parang itim na
    di ko mapost ung pic hehe
    Jan 2010
    #829
    Quote Originally Posted by Sgear1 View Post
    I just checked ACE Hardware. No luck there, either.
    #830
    For the Klasse/Carlack you can try Extremedetail at Pinoydetailing.com. Send him a PM.
    Aug 2008
    #831
    Look for Carlack (virtually the same product, just different label) at Big Berts or MC Home Depot.
    Aug 2008
    #832
    Quote Originally Posted by rmgbigbrother View Post
    TIA sa mag input
    As always, least aggressive option first. If a wash does not remove them, you can try, in succession:
    1. non-abrasive chemical cleaner (Klasse All In One, Meguiar's Deep Crystal Paint Cleaner)
    2. mildly abrasive cleaner or polish (Mother's Pre-Wax cleaner, Meguiar's Ultimate Polish)
    3. medium abrasive polish (Meguiar's Swirl-X, Meguiar's Scratch X 2.0)
    4. aggresive compound (Meguiar's Ultimate Compound)
    Please don't use anything more aggressive than Megs UC (even that is a very aggressive product already) - you risk thinning your clear coat unnecessarily (and possibly dangerously) with old-school rubbing compounds. After you get the watermarks out, do protect your paint with a wax or sealant.
    Aug 2008
    #833
    Quote Originally Posted by shotgun View Post
    Well, a proper three-step detailing consist of compounding, polishing and finish polishing. However, not all cars require all three steps - in some cases you might not need to compound; in other cases, the finish left behind by the polish is good enough not to warrant a finish polish. I'm not familiar with 3M rubbing compound - a quick search shows that there are multiple 3M products which are all called rubbing compound, some of which are for hand use only, some for machine use. My advice? Get the work done at a reputable place such as Big Berts, or hire a detailer to do it. (I can PM a few names if you want.)
    Aug 2008
    #834
    Quote Originally Posted by sher_winpig View Post
    We really need to see it to at least have a chance of telling :D
    Oh, and there isn't any wax, polish or compound in the world that will remove dents :D
    Is it in the bumper? (nakikita yung parang itim?)
    #835
    Hmm, I have a 6-inch long scratch on the lower side of my front bumper. It's not in the underside so it's still visible from some angles, which is why I kinda want it removed.
    My first option was to have it touched-up. I asked my friend how much it'll cost in their family's paint shop (The Wet Look), mga 3k daw.
    Are there any other cheaper alternatives? Kung wala, I can leave it there. I'm just being a bit OC about it
    Jun 2007
    #836
    is it normal to still have remaining swirl marks after having a vehicle exterior detailing by a shop? 6 hours nila ginawa.
    Mar 2012
    #837
    Its not normal. The person lacked experienced in removing swirl marks or did the damage themselves.
    Jun 2007
    #838
    Quote Originally Posted by onemph05 View Post
    most probably nga sir. i asked him about it and he answered baka kailangan gumamit ng sandpaper.
    Oct 2008
    #839
    wtf. sand the spiderwebs
    jut, still try to touch it up. Best to use a bit of putty but if you don't wanna.. the process is clean, touch up, sand. Rinse and repeat then polish. When done, since it is very close to the underside it probably is noticeable only by you. If you can't then prepare your 3k.
    Mar 2012
    #840
    A great detailer will have a variety of cutting pads and compounds to remove swirl marks.
Detailing Thread [For Newbies][continued 3]
