Results 321 to 330 of 2535
- Aug 2008
- 965
April 21st, 2011 12:20 AM #321
April 21st, 2011 01:08 AM #322
double post...
Last edited by cjv_justice; April 21st, 2011 at 01:24 AM. Reason: multpile posting
April 21st, 2011 01:11 AM #323
here's the thing sir, my FD is almost 5 years na. With light scratches and some swirls narin, suking carwash treatment. E ngayon lang ako na-engganyo sa detailing so I think I'll get the Moms Step1 for her.
When you say paint is in 'good condition', I'm assuming parang brand new. With that being said, I'll use KAIO for the Altis.
April 25th, 2011 11:14 AM #324
DTfN started this day, six years ago. only about 5% of car owners get afflicted of this hobby as there is only a small set of circumstances to push one into it.
A lot of Q&As and shared experiences to get that flawless, new car look is contained in the thread. as in mathematics where one can use simple algebra to come to an answer, others may also choose exponentiation, calculus, logarithms, algorithms! to arrive at the same answer.
thanks for the peeps from the start and those who followed. a lot of hours have been spent in posting info and experience so thanks also to the readers who are kind enough to not have the authors reiterate.
start with simple detailing steps in the beginning. don't get paralyzed by analysis or fear, there's enough info to get you started. Later, keep it simple or further complexity.
i'm sure quite a few OCDs have been inspired by this thread and came out fully fledged, capable of furthering their skills using the vast resource of the net, decisively testing and learning how and what really works.
happy anniv
- Aug 2008
- 965
April 25th, 2011 12:58 PM #325
April 25th, 2011 02:13 PM #326
from what i recall from my backreadings, there's the bigberts team, a poorboy's world rep, and the diyers who are quite capable themselves. madkatz/ed who tested a lot of products and techniques, helped everyone day in&out.
i don't know the lurkers, i hope they share later.
i dare not PM the detailing vets, they've helped everyone enough. congrats na lang sa dami ng nahawa, natulungan at nainspirang magpatuloy nila. di biro ang OCD.Last edited by indiej; April 25th, 2011 at 02:15 PM.
- Apr 2011
- 148
- Jul 2010
- 169
June 11th, 2011 08:07 PM #328guys ask ko lang.. san nakakabili ng pads para sa rotary buffer kasi balak ko bumili nung BnD na 7inches yung tig 6k php, yung may settings na 1 to 6, eh wala siya kasamang matinong pad.. san ba nakakabili? salamat, kung may nag bebenta sa inyo gusto ko bumili brand new sana, 0927 430 55 38,
musta mga detailing masters?! i'm back !!
*chikselog (migz) ingat ka dyan sa singapore !!
June 11th, 2011 09:26 PM #329
June 23rd, 2011 08:27 AM #330
Autoglym research regarding bird dropping ph effect
Bottomlines that substance plus temperature change cause the damage on paint
ttp://www.autoglym.com/enGB/News-latestfull.asp?v06VQ=HIK
NEW RESEARCH DISPELS MYTH OF WHY BIRD DROPPINGS DAMAGE PAINT
[SIZE=2]Research from Autoglym reveals bird dropping ‘acidity’ has no effect on paintwork
Damage results from cooling paint lacquer contracting and moulding around deposits
Autoglym warns motorists to act fast and with care to prevent lasting damage
New research from Autoglym, the UK’s leading car care experts, suggests that the familiar sight of car bodywork ‘etched’ by bird droppings are not the result of any corrosive property in the deposit, as is commonly believed. In fact, damage instead results from the paint lacquer contracting upon cooling and moulding to the uneven texture of the hardened deposit.
As paint lacquer warms – in the direct summer sunshine for example – it softens and expands. At the same time, that heat dries and hardens any bird droppings on the surface. Autoglym’s researchers discovered that as the paint lacquer cools, overnight for example, it contracts, hardens and moulds around the texture of the bird dropping. To the naked eye, this moulding at a microscopic level appears as dulled or etched paintwork. The light’s reflection is interrupted by the imperfect surface, unlike the undamaged paint surrounding it which gives a clearer reflection.
Autoglym’s tests with strongly acidic, neutral and strongly alkali bird dropping substitutes highlighted negligible differences in the damage caused. However, differences in paint damage were noted when the substitute bird deposits had varying degrees of grain-to-liquid content. A grainier texture caused greater light distortion (dullness) when the paint moulded around it.
Wax and polish treatments – that protect against chemical attack from acid raid and UV sun damage, for example – provide limited protection from the paint moulding to bird droppings, although they will make them easier to remove. The longer the deposit remains on the bodywork, and the higher the temperatures, the harder the dried deposit will be, and the greater the propensity for the paint lacquer to mould to it as it cools. Bird dropping damage can only be prevented by motorists remaining vigilant and removing the deposit as soon as possible.
Autoglym’s has outlined some tips for minimising the risk of damage from bird droppings:
- Remove the deposit at the earliest opportunity
- Motorists should use a moist cloth – Autoglym’s Bird Dropping Wipes are ideal – to gently lift the deposit from the surface
- If the deposit is dry or doesn’t lift easily, place a moist cloth over it for ten minutes to soften the deposit
- Dispose of any cloth or wipe used to remove bird droppings immediately and carefully wash your hands, as bird lime can harbour diseases
Paul Caller, CEO of Autoglym, said: “It’s a great shame when an otherwise fabulous-looking car is blighted with a tell-tale patch of dull paint. As a result of this new research by our R&D team in Letchworth, we now understand why bird droppings are a frighteningly potent hazard to bodywork.[/SIZE]
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
