Page 45 of 79 FirstFirst ... 3541424344454647484955 ... LastLast
Results 881 to 900 of 1575
    Jun 2005
    #881
    WHAT: BASIC DETAILING FOR BEGINNERS
    WHERE: SOMEWHERE SA KATIPUNAN
    WHEN: DEC 5, 2010 (SUN)
    TIME: 8am
    TOPICS:
    1) HOW TO PROPERLY WASH YOUR CAR
    2) STEP 1-2-3 ON 1 PANEL ONLY (WITH POLISHER/BY HAND)
    3)WHEEL detailing
    4) product knowledge
    PARTICIPANTS
    1) PSI
    2) Hardinero
    3) Chikselog - tentative
    4) kErikzb
    5)
    pwede po manood? Kaso mawawala ako sa katips! haha! painform na lang po san banda doon at if possible directions from taft ave /quirino ave. Thanks!
    #882
    *bombit, may pm ako syo. thanks.
    #883
    Jul 2006
    #884
    Quote Originally Posted by rockstar5k View Post
    idol kakausap lng natin ah? hehehe
    #885
    Quote Originally Posted by dotnetmatt View Post
    Hehehe. need ko talaga yung specific number sa counterweight. It has something to do with the vibrations sa pc. hehehe. I doubt kc kung basic PC kit lang bibilihin ko, 6" cw ang ksama nia.
    Aug 2009
    #886
    Quote Originally Posted by indiej View Post
    And after watching a video of it, application is a PITA vs the foam cannon.
    i got two. maybe i'll sell the other one later. at 5T? i left the bottles for a smaller package. i use the portable bnd. 1400W
    i got kew/alto fittings but the thread is for a screw type lance which is a pain because it is 1/2" with bigger threads vs. the standard 1/2" NPT. i had to thin the tapered end of bayonet according to the bnd bayonet by 1mm diameter and tap the inside of the other end with 1/4" NPT so i can screw in a 1/4" nipple plus Teflon tape.
    the ordinary spray bottles and 1.5L softdrink bottles fit. the hose for the bottle is a thick transparent one. this one you cannot change at whim because the grooved connector cuts and hooks into the rubber. the hose curves inside a shorter bottle so no issue there.
    the foam cannon has a very high pressure rating around 150 bar ~ 2000+ psi so i don't think it's the cannon, but i would guess a foreign part came into the all-brass body internals. can all the passages be checked? what about having it warrantied? what's the link to the dismantling procedure?
    i want a clingy foam. tornador can make mousse.
    excuse moi, i'll get back to this and to you guys later, social duties acalling..
    Hmmm is the process of retrofitting the kew/alto fitting to adapt BnD pressure washer hard? or can it be done with some patience? can i ask for some help if im going to consider taking the same route as yours?
    Im thinking of just getting a BnD PW just for the sake of having it 220volts, my Bf's maid out of curiosity plugged his PC 7424 on a 220volts socket and it burned right down to the bread board, so its far from any hope of being repaired and knowing how some maids can be "so curious" im talking every possible caution now
    here the link to dismantling and servicing the foam lance if ever something gets stuck or something needs to be cleaned like the wire mesh
    http://www.detailingworld.com/forum/...ad.php?t=84349
    hope this helps, i know after sometime you might need this read because we sure did, we had to do that procedure twice in the foam cannon's 2 year life span, as for warranty it seems like its more expensive to ship it over to AG and ship it back again rather than just order it again
    Aug 2009
    #887
    Quote Originally Posted by mada View Post
    ok..thanks po..yup microtex nanoglos po before 915.
    pictures would help us a lot in determining what those white spots are
    Aug 2009
    #888
    Quote Originally Posted by tribal View Post
    bibili ako sa sunday ng carnauba wax.3 choices lang po... 1. mothers step 3 (carnauba wax) 2. turtle wax (ultra gloss) 3. F21. hingi sana ko ng advice alin ang mas tatagal at mas makintab sa tatlo?
    im currently using turtle cleaner wax, makintab naman sya kaya lang parang bitin yung kintab. by the way medium silver pala yung color (altis).
    as with their suggestions, get 476 instead, its a lot better and more economical
    #889
    *madkatz,
    nice post #. hehehe
    Oct 2008
    #890
    Quote Originally Posted by madkatz View Post
    it's simple enough if you have the tools. i just bore into the plastic fitting itself and threaded (tapped) the inside to fit the 1/4" nipple.
    i also thinned the diameter of the bayonet part with the o-ring by 1mm. you can bring it to a machine shop so you won't have to worry about this one-time conversion.
    i imagine the same could be done to the bayonet of the soap dispenser of the BnD. but i haven't dared cutting it off as i'm just about to buy my own unit ;)
    don't be silly, of course i'll help.
    ..my Bf's maid out of curiosity plugged his PC 7424 on a 220volts socket and it burned right down to the bread board, so its far from any hope of being repaired ..
    i realized i covered my face subconsciously.
    you could bring the kaput PC to an electrician friend cos most of them know how to convert from 110v. at least you can then gauge if it's feasible.
    Mar 2005
    #891
    Quote Originally Posted by kerikzb View Post
    TIME: 8am
    TOPICS:
    3)WHEEL detailing
    PARTICIPANTS
    1) PSI
    2) Hardinero
    4) kErikzb
    5)
    +1 sa location. Baka pwede ako dumaan before ako pumasok.
    #892
    ...my Bf's maid out of curiosity plugged his PC 7424 on a 220volts socket and it burned right down to the bread board..
    If I have the chance to drop-by dwin's place, pwede ko tingnan yung pc. I might assess kung for disposal na yung pc or may remedyo pa. .
    #893
    ...ooops! double posts...
    Apr 2010
    #894
    Pero if sa tatlo po na choices alin po mas ok?i already texted yung auto bisyo if nakasale pa un pero di ako nireplayan so malamang wala na po un.
    Jan 2010
    #895
    Quote Originally Posted by rico_g View Post
    That's an excellent combo... it's the same combo I use, except 476s ang gamit ko instead of 915... here's my regimen:
    every 6 months
    Step 1
    Nano Glos
    476/915
    OCW
    OGE/NanoSliq
    every 3 months
    Nano Glos
    476/915
    OCW
    OGE/NanoSliq
    Every 2-4 weeks
    476/915
    OCW
    OGE/NanoSliq
    Weekly
    OCW
    OGE/NanoSliq
    After wash:
    OGE/Sliq
    I highly recommend uyou get OCW too para tumagal ung 915. I use to wax every 2 weeks, pero with OCW every month na lang...
    enjoy detailing pafs!
    wow this is a good advice sir....salamat po.
    Jan 2010
    #896
    Parehong-pareho tayo ng regimen idol rico. hehehe. *mada, you can try using nanogloss to clean those marks first, it has light cleaners kc depende kung pano mo cia ia-apply. When you top off mom's step 1 with 915/476, you should do IPA wipedown para kumapit sila ng husto. May wax/oils kasi ang mom's step1.
    sir ano po yung IPA wipedown? pasinsya na diko kasi na try yan.
    ito kasi gagawin ko.since almost 1 year wash and wax lang ang ginagawa ko.
    every 6 months
    Step 1
    Nano Glos
    476/915
    OCW
    OGE/NanoSliq
    #897
    every 6 months
    Step 1
    Nano Glos
    476/915
    OCW
    OGE/NanoSliq
    IPA=Isopropyl Alcohol. You can use greencross 70% isopropyl alcohol (without moisturizer). I-dilute mo 50/50 with distilled water. spray on the panel then wipe off agad.
    Mar 2004
    #898
    para saan po ba ang IPA wipedown? ano ng benefit ibibigay nito?
    Jan 2010
    #899
    ok thanks...i'll do that.
    i think para kumapit ng husto yung wax na ilalagay after mag apply ng mom's step1.kasi max wax/oil to.
    Mar 2004
    #900
    then if that's the case which is better AIO or IPA wipedown?
Detailing Thread [For Newbies][continued 2]
