Quote Originally Posted by madkatz View Post
Its the Ace sprayer bottle that has a hole for pressure release, it actually becomes a PITA once you fill it up to that point it touches the pressure release hole or once you tilt the sprayer and it touches the pressure release hole since it will leak out the contents
And after watching a video of it, application is a PITA vs the foam cannon.
Wow you also took the plunge for a foam cannon, what pressure washer are you using with your foam cannon? and what fitting did you use? any needed modification?
i got two. maybe i'll sell the other one later. at 5T? i left the bottles for a smaller package. i use the portable bnd. 1400W
i got kew/alto fittings but the thread is for a screw type lance which is a pain because it is 1/2" with bigger threads vs. the standard 1/2" NPT. i had to thin the tapered end of bayonet according to the bnd bayonet by 1mm diameter and tap the inside of the other end with 1/4" NPT so i can screw in a 1/4" nipple plus Teflon tape.
the ordinary spray bottles and 1.5L softdrink bottles fit. the hose for the bottle is a thick transparent one. this one you cannot change at whim because the grooved connector cuts and hooks into the rubber. the hose curves inside a shorter bottle so no issue there.
I had to order another foam cannon since our first one sort of broke down..
..we connected it to my pressure washer not knowing mine was a lot stronger, upon using we heard a plastic sound that cracked and took the cannon apart but upon closer inspection everything seems fine, we followed the cleaning guide and disassembly guide by someone from Detailworld and didn't find anything wrong but since then its no longer working properly ..any suggestions?
the foam cannon has a very high pressure rating around 150 bar ~ 2000+ psi so i don't think it's the cannon, but i would guess a foreign part came into the all-brass body internals. can all the passages be checked? what about having it warrantied? what's the link to the dismantling procedure?
BTW, with our first foam cannon we used Megs Hyperwash and DG shampoo to get really thick foam
i want a clingy foam. tornador can make mousse.
excuse moi, i'll get back to this and to you guys later, social duties acalling..
