Results 881 to 890 of 1575
November 26th, 2010 12:15 PM #881
WHAT: BASIC DETAILING FOR BEGINNERS
WHERE: SOMEWHERE SA KATIPUNAN
WHEN: DEC 5, 2010 (SUN)
TIME: 8am
TOPICS:
1) HOW TO PROPERLY WASH YOUR CAR
2) STEP 1-2-3 ON 1 PANEL ONLY (WITH POLISHER/BY HAND)
3)WHEEL detailing
4) product knowledge
PARTICIPANTS
1) PSI
2) Hardinero
3) Chikselog - tentative
4) kErikzb
5)
pwede po manood? Kaso mawawala ako sa katips! haha! painform na lang po san banda doon at if possible directions from taft ave /quirino ave. Thanks!
November 26th, 2010 12:29 PM #884
November 26th, 2010 01:12 PM #885
- Aug 2009
- 1,553
November 26th, 2010 01:46 PM #886Hmmm is the process of retrofitting the kew/alto fitting to adapt BnD pressure washer hard? or can it be done with some patience? can i ask for some help if im going to consider taking the same route as yours?
Im thinking of just getting a BnD PW just for the sake of having it 220volts, my Bf's maid out of curiosity plugged his PC 7424 on a 220volts socket and it burned right down to the bread board, so its far from any hope of being repaired and knowing how some maids can be "so curious" im talking every possible caution now
here the link to dismantling and servicing the foam lance if ever something gets stuck or something needs to be cleaned like the wire mesh
http://www.detailingworld.com/forum/...ad.php?t=84349
hope this helps, i know after sometime you might need this read because we sure did, we had to do that procedure twice in the foam cannon's 2 year life span, as for warranty it seems like its more expensive to ship it over to AG and ship it back again rather than just order it again
- Aug 2009
- 1,553
November 26th, 2010 01:48 PM #887
- Aug 2009
- 1,553
November 26th, 2010 01:48 PM #888
November 26th, 2010 03:51 PM #890
it's simple enough if you have the tools. i just bore into the plastic fitting itself and threaded (tapped) the inside to fit the 1/4" nipple.
i also thinned the diameter of the bayonet part with the o-ring by 1mm. you can bring it to a machine shop so you won't have to worry about this one-time conversion.
i imagine the same could be done to the bayonet of the soap dispenser of the BnD. but i haven't dared cutting it off as i'm just about to buy my own unit ;)
don't be silly, of course i'll help.
..my Bf's maid out of curiosity plugged his PC 7424 on a 220volts socket and it burned right down to the bread board, so its far from any hope of being repaired ..
you could bring the kaput PC to an electrician friend cos most of them know how to convert from 110v. at least you can then gauge if it's feasible.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
