Results 11 to 20 of 1575
October 12th, 2010 11:13 PM #11
may kapares pa yan meron din siya clear coat safe na polishing compound. Para sigurong ultimate compund at swirl x in paste form.
October 12th, 2010 11:22 PM #12
Cleaner wax siguro sir EJ, or compound, depende sa defects.
Yung Stage 2,3 detailing nila BB, yun yata yung compound + polish + wax. Defect removal yun ng whole car AFAIK.
Regarding next detailing EB, ewan ko lang hehe. Pero sana meron this October, sembreak ko na next week!
October 13th, 2010 12:34 AM #14
Di ko pa na try kasi pang hand application lang siya.Mukhang ok naman siya dito sa vid. Clear coat safe meaning hindi siguro siya nag cacause ng marring sa paint unlike yung mga rubbing compound ng 3m/turtle wax na na nagiging dull yung paint afterwards.
[ame="http://www.youtube.com/watch?v=byRA0lCXpzg"]YouTube - How To Use Meguiar's 2010 NEW Rubbing and Polishing Compound[/ame]
- Aug 2009
- 1,553
October 13th, 2010 01:18 AM #15with OCW you just use it like a QD but on a clean surface, you apply some on the MF first and about just one spray on the panel will do, this will already cover a lot of paint area
as with the Zaino question, it depends z5 can be layered immediately after doing the whole car and removing it from the whole car, once you done, you're ready to layer again starting from the first panel you previously layered, but this is best if left for 4 hours based on experience with the zfx, with Z2 if needs about 4 hours minimum for extended durability and 8 hours recommended, the producer says it can be layered immedaitely after doing the whole car but i don't that it doesn't stack as much when done this way
- Aug 2009
- 1,553
October 13th, 2010 01:26 AM #16Like what JM said, clear coat safe simply means it doesn't induce marring, hazing and dulling once used, this product is a combination of different kinds of abrasives and still needs to be worked on to perform flawlessly.
its actually a great product and although it won't give you marring and hazing it would still lack the gloss so you have to follow it up with the polish which is like its step 2
its very good via hand application pretty much like Megs UC but has an oilier feel and longer working time
this is highly recommended for recessed door handles, door frames, the painted panels inbetween the grills, and etc, basically its great for doing small panels of paints that are basically hard to reach using a buffer, but again follow it up with the polish
i wouldn't really recommend this product for doing the whole car its more likely something you would use for spot treatment and degrimming
this is also one of the better scratch removers we use, better than scratchX in terms of leveling deeper scratches and RIDS
Hope this helps
- Aug 2009
- 1,553
October 13th, 2010 01:29 AM #17GREAT JOB!!
i like the hood shot!
but i think you might want to alter you process
Wash, SwirlX, IPA Wipe, Nano Glos and OGE would be fine
if ever it would be
Wash, SwirlX, Cleaner Wax, Nano Glos and OGE
but wash, swirlX, IPA, Nano Glos and OGE is already great
SwirlX already leaves a brilliant finish
- Aug 2009
- 1,553
October 13th, 2010 01:31 AM #18Hello, i think he would be free this weekend since so far we still don't have any plans and none scheduled on our calendar
I would recommend you show it to him personally so that he could asses the problem better, that way you could try and find out which one works and which one doesn't as usually we always go the safest route.
October 13th, 2010 01:40 AM #19
October 13th, 2010 02:08 AM #20
Kung paint overspray lang kaya tanggalin ng clay bar yan since above surface contaminant ang overspray and hindi masasayang yung clear coat mo
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
