Page 252 of 296 FirstFirst ... 152202242248249250251252253254255256262 ... LastLast
Results 5,021 to 5,040 of 5910
    Aug 2009
    #5021
    Quote Originally Posted by azzkkr2600 View Post
    * rockstar: how much ang B&D KP600 kaya dyan sir? i remember na kelangan yata na palitan yun backing plate na may velcro + LC pads (what size and type?).. so malaki din ba aabutin at better option ang makita 9227c or B&D wp1300? lito na ako sa pagpili ng buffing machine..
    Well the kp600 doesn't vary that much in terms of price compared to the wp1300 and you get real correction from wp1300, so for me it all boils down to the following questions
    Can you alot enough time to learn how to use rotary and have the patience of using a rotary?
    If yes and then go for the wp1300, if not stick with kp600, then again kp600 is only ideal for spreading liquid products.
    What are your goals in buying a polisher?
    If its just to save time waxing then its kp600, if its to correct and paint and make it look great then its wp1300
    How far are you willing to go after buying a polisher?
    kp600 requires less add ons to work well, the wp1300 needs more items like backing plate, pads and polishes and compounds, pad spurs
    so basically for those that just want to make their vehicle look nice without improving paint then kp600 is ok, but for those with defects and can't stand not to remove them like me hehehe then i would suggest wp1300, of course the Makita is way way much more expensive but for me my Makita was well worth every buck because i really bust my arms with the wp1300 since its a lot heavier, try polishing for 3 to 4 hours and you would notice the difference
    Aug 2009
    #5022
    Quote Originally Posted by mf051404 View Post
    How about nanoSLIQ ma'am? since you mentioned it has cleaning properties, it can then be used as a pre-wax cleaner then topped with say collinite 476s (because I'm thinking of the spray wax characteristic you mentioned, 476 might not stick to it thus reducing 476 durability)? or nanoGLOS then colli476s is better?
    Since I have nanoGLOS, nanoSLIQ, Collinite 476s, which sequence is better (of course after washing) in your opinion?
    1. NanoGLOS -> nanoSLIQ -> collinite 476s
    2. nanoGLOS -> collinite 476s -> nanoSLIQ (for maintenance)
    3. nanoSLIQ -> collinites 476S (since first two might be overkill)
    4. collinite 476S -> nanoSLIQ (same reason as #3)
    Nano Sliq's cleaning properties only go as far as removing light dusts, bird droppings and tree saps that are not yet baked on, its also enough to remove some types of adhesives and sticky road films but thats just about it but it can't be used as a pre wax cleaner and yes very big chance it would affect the 476 so i would recommend you go with sequence number 2, Nano Glos for beauty and looks, collinite 476 and Nano Sliq as maintenance
    Aug 2009
    #5023
    As for the interior ceiling, what could be done to clean it myself? Yung "carpet" ceiling kasi nung sasakyan is closely knit (walang himulmul)...tried using a carpet cleaner (yung tipong nagfo-foam then wipe off lang) kaso ang problema is nagkahimulmul na sya. Gusto ko sana malinisan lang sya na hindi maging "hairy" ang appearance nya (yung makinis pa din), meron bang product for this purpose?
    BTW yung sasakyan is Nissan XTrail, baka merong may xtrail dito na nakapaglinis na ng kanyang ceiling na hindi naging "hairy" and after effects
    Oh for that you need a really good all purpose cleaner, Megs sells some that are great, be sure to vacuum it first and then apply the APC and wipe it on a linear motion always towards one direction with a very soft foam sponge, this would great lessen it being frizzy during the cleaning process and then don't wipe it dry with a rough towel, use a soft cotton or MF towel and again wipe it in a linear motion always towards one direction only
    Jun 2010
    #5024
    Quote Originally Posted by madkatz View Post
    Thanks! Nice explanation...
    Jun 2010
    #5025
    Thanks for the tip...I'll try that
    Jun 2010
    #5026
    Jun 2010
    #5027
    Mga sirs what do you recommend to use for removing double adhesive tape marks... its very fine kasi ang hirap tanggalin.
    Jun 2010
    #5028
    Jun 2010
    #5029
    Sorry, doble doble na ang post...
    Feb 2010
    #5030
    * sir edwin / ma'am madkatz: is the Elite still available? how about ONR? magsked kami pumunta uli ni psi, chikselog, dotnetmatt, scharnhost, golti, beeco, rockstar, etc to buy some products again.
    do u have buffer pads (available for the customized kp600) that i can use after applying wax (either 476s or nanoglos) by hand?
    * psi: sir galing talaga ng OGE! pati nanosliq galing sa beading! panalo!
    * silverrain: OGE is Optimum Gloss Enhancer. this is a QD like the microtex nanosliq and mothers showtime. nanosliq has the best beading effect though.
    o sched ninyo na kung kelan tayo punta....sabay toma na rin...kung gusto ninyo saamin na lang tayo toma.....habang tirahin ko yung honda LOL...
    *AZZ...aba tinuluyan yung makina....taasan mo na rin kaya yung wax mo para sulit yung makina..... lista mo na yung mga bibilin natin...I would really like to buy yung pang degrimer(?).....beading ba kamo.....kukuha na rin ako ng nanosliq....pang alternate ko sa OGE
    #5031
    *madkatz, thanks so much. Went to glorietta yesterday, grabe price ng 9227 sa truvalue, ~Php18500! Maybe because they offer 3mos 0% interest. I'm leaning towards buying 7424xp or 9227c. Will do some research first. For the meantime, tyaga muna ako sa manual wax removal.
    *azzkkr2600, i'll will inform you guys re price sa sta cruz re polishers. Anyway, meron na pala Microtex Products sa ACE Hardware Makati in sachet form. Inform me na lang kung kelan tayo punta kay sir Edwin for shopping spree! Mamamakyaw na naman si psi nyan. hehehe. Need ko ONR!
    Aug 2009
    #5032
    Quote Originally Posted by silverrain View Post
    is it on the paint? if its on the paint you could try removing it with kerosene or lighter fluid but don't let it sit too long just pour some on the area, let it sit a little and remove with a cotton ball, and the follow it up with some polish to make it look nice again and wax to protect the shine, if you're using kerosene its a lot safer, the lighter fluid is a lot more effective but be sure to remove it within like 10 seconds.
    Aug 2009
    #5033
    Quote Originally Posted by rockstar5k View Post
    for starters i would really recommend the porter cable 7424 xp, that way you will gradually know the limits of paint correction and how to visually see at a much slower rate how paint corrects and polishes cut.
    Jun 2010
    #5034
    Thanks madkats yes sa paint po sya. Double adhesive tape kaya ang nipis at makapit talaga. I hope kerosine does the trick. Thanks much.
    Feb 2010
    #5035
    LOL!! la na ko pambili....ONR/DOUBLE ACTION/mga towels na lang malamang ang bilin ko.......di pa tapos yung project ko sa audio nak tokwa.....bili pa ko goma....nu ba yun...... sana matuloy ka swap ko ng 16" ganda ganda .....uy magkano makina?????
    Dec 2003
    #5036
    Pwede po sir!
    Yup especially if its Nano Glos, i like using Nano Glos as a beauty wax because i find more waxes bond to it without causing problems, i guess because it doesn't finish off oily.
    Thanks for the replies. I'm a bit apprehensive about mixing brands and experimenting but this coming from experienced detailers gives me the confidence to go ahead.
    Mar 2005
    #5037
    so basically for those that just want to make their vehicle look nice without improving paint then kp600 is ok, but for those wiTth defects and can't stand not to remove them like me hehehe then i would suggest wp1300, of course the Makita is way way much more expensive but for me my Makita was well worth every buck because i really bust my arms with the wp1300 since its a lot heavier, try polishing for 3 to 4 hours and you would notice the difference
    +1 sa kp600 kung pang apply lang ng glazes pre wax cleaners, glazes, wax at sealants ok ang modded kp600. Kahit may portercable na ko gamit ko pa din kp600 ko. Overkill para sakin kung gagamit ng rotary kung mag aaply lng ng waxes at sealants.
    Mar 2005
    #5038
    Go for pc7424xp sobrang safe siya para sa mga newbies. Kung mag bubudget ka mag allot ka din para sa stepdown transfomer na atleast 750 to 1000watts.
    #5039
    Quote Originally Posted by jmpet626 View Post
    thanks sir jmpet!
    Mar 2005
    #5040
    thanks sir jmpet!
    Sir san kayo banda sa project 8? Kita ko kasi sa sig nyo
