well the "rule of thumb" is when you can feel the scatch with your nails or fingers its an automatic paint job, detailing can only do so much on a scratched surface. Using rubbing compound should be the last resort and should be only used by hand not by machine because it will remove the clearcoat if your not carefull. One of the good uses of rubbing compound is for removing paint transfered from another object.
