Page 185 of 296 FirstFirst ... 85135175181182183184185186187188189195235285 ... LastLast
Results 3,681 to 3,700 of 5910
    #3681
    *madkatz
    Question lang po.. If I detail with Mother's Step 2 and 3 ngayon, Hindi po ba matatanggal yung pinadetail ko sa BB na double wax last saturday? We will be away kasi for a couple of days so I'd like to boost its protection for the meantime..
    TIA
    Aug 2009
    #3682
    *thx777: there is no curing time after applying Step 2, the only products that have curing times are pure waxes and sealants, for sealants its 24 hours for optimal durability and 12 hours minimum, and for waxes its 8 hours for optimal durability and 4 hours minimum, thats what most sites say, and as for polishes where step 2 falls under, there are no curing time needed, oh yeah for step 2 you might want to work the product a little longer with very very light pressure, i find this to make the most of the fillings capabilities and to burnish the paint to a high gloss, Actually Dark Blue is actually one of the easy colors to achieve a mirror finish, take a look at the Exped i detailed, thats dark blue paint, and using step 2 can really help in bringing out that crisp reflections.
    Aug 2009
    #3683
    *jozep: very nice, very clean paint, not a spot out of place, nice reflection for a light colored car and thats some great sheeting, the sheeting on your car is actually better i think than mine, mine still has some pools left and the 4th picture has a lot less considering thats a flat surface. great job!
    Aug 2009
    #3684
    *Chikselog: if you use Step 2 and 3, yes would you just end up removing the FX wax applied by BB, the step 2 contains very very mild polishes that can remove wax, if you want to boost the protection of the car, just use Step 3, im sure the paint right now is still clean from the double wax and slapping on an extra layer of carnauba would already do a great job for protection when ur gone.
    #3685
    *madkatz
    Thanks! I guess I'll just be extra careful in washing
    #3686
    Saan po nakakabili ng porter cable dito? and anong pads ang dapat kong kunin? newbie lang po ako
    Apr 2010
    #3687
    Hi mga Tsikoteers! - Newbie member lang...
    Sorry if I'm going to ask a repetative question, too many posts already medjo nahihilo na ko sa dami...
    I just wanted to ask advice regarding taking care of my APV.
    Details:
    Suzuki APV - White
    7 months old na siya.
    I read that there are some waxes, cleansers, sealants, etc etc... sorry nahilo talaga ako.. and I read na meron na dapat once a month lang kasi mauubos daw yung top coat nya.. which im afraid to use.
    I just wanted that extra coating of protection for my paint.. and a good shine...
    Thank you in advance sa makakatulong.
    Dec 2009
    #3688
    jozep,
    Ang ganda nung pag wax sa puting kotse. Iba talaga pag nadetail ng maayos ang white color. Parang white ang gusto ko maging kotse next time.
    #3689
    Quote Originally Posted by olidotcom View Post
    Details:
    Suzuki APV - White
    Sir yung once a month na tinutukoy nyo yun siguro yung mga waxes na may mild cleaners or mild to very mild abrasives. Usually yung mga ganitong waxes, pang-prepare lang ng surface ng paint para mag bond properly yung wax and pang remove ng light surface defects, example is the Mother's Step 1 Pre-Wax Cleaner.. Actually dapat 2-3 times a year lang dapat ginagamit ang mga ganitong waxes..
    Sealants are more durable than waxes.. Read na lang po natin yung recent post ni madkatz about that
    Waxes. Eto it can be used once a month. It is safe for the paint, just follow the correct applying procedure. Minsan kasi we tend to put pressure on the paint therefore narereduce ang clearcoat pero very minimal lang naman. Waxing once a month is already a very good practice dahil may protection ang paint natin from the heat of the sun..
    Kapag rainy season naman, if you have time, it is best to wax your car at least once a week..
    #3690
    Ano difference ng pre wax cleaner sa cleaner wax?
    Mar 2004
    #3691
    Quote Originally Posted by daney_waney View Post
    Pre-wax cleaner will remove the dirt from your paint (oxidized paint, road film, etc.). This will make it easier for the wax to bond with your paint. Note that pre-wax cleaners do not have wax.
    Cleaner-wax is a combination of pre-wax cleaner and wax.
    Jan 2009
    #3692
    Quote Originally Posted by madkatz View Post
    Thanks madkatz, for the samples.
    I'll try to post the results of the Microtex Tire Cream tonight.
    Jan 2009
    #3693
    Quote Originally Posted by water View Post
    jozep,
    actually hindi po talaga sya white, opal color sya.
    I also prefer light colored cars kse hindi masyado halata yun mga minor scratches, pero you'd more appreciate the shine of your car pag dark colored like yun kay sir jmpet626 & Starex_Gold.
    Dec 2009
    #3694
    Sa ganda kasi ng white color napapaisip talaga ako. Gusto ko kasi helios yellow ng jazz pero napapaisip ako sa tafetta white.
    Gusto ko rin kasi sa white bumabanda yung sinag ng araw so hindi mainit.
    Jan 2009
    #3695
    Here are the results of Microtex Tire Black:
    It looks glossy after applying, but when it dried it became like flat black.
    Before:
    After:
    Before:
    After:
    Jan 2009
    #3696
    Continuation:
    Apr 2010
    #3697
    Thank you for the advise! ill do that!
    Aug 2009
    #3698
    *daney_waney: you could get the PC 7424 but not the new XP model at mothers distributor, for 15k, honestly you could get it cheaper buying it from the US, my friend just sold his brand new 7424xp for 10k with a few pads just because he wanted a better model so he bought a flex 3401 instead, you could probably look around and ask some enthusiasts that might sell them, but the only problem with PC7424 would be that they're 110v and they don't come with warranty although these things last you a really really long time.
    #3699
    Thanks to madkatz and to her bf for the samples! I will try it after the 15K PMS, so maybe next week yun ..
    *madkatz
    Onga pala, which comes first? Mother's Step 3 or the NanoGLOS?
    Aug 2009
    #3700
    *olidotcom:
    Cleaner Waxes - are basically waxes with polishes, this type of wax is one of the basic waxes someone needs to maintain a great finish, equally important compared to pure waxes and sealants, it contains mild polishes which are mainly used for removing oxidized paint and old wax build ups, the mild polishes can remove very very light scratches and swirls, and for the deeper ones it can remove the dirts and grime stuck in between, its also recommended for cars 2 to 3 years older to restore the clarity and make the metallics pop, its advisable to use cleaner waxes at regular intervals or quarterly to maintain a clean finish and to make sure the new layer of wax bonds directly to the paint
    Mothers Carnauba Cleaner Wax
    Deep Crystal Cleaner Wax
    TW Carnauba Cleaner Wax
    Pure Waxes - as the term says is made of natural pure waxes, carnauba being the most popular, bees wax and bavarian montan and etc, these waxes doesn't contain any polishes that might abrade or reduce the clear coat, these type of waxes provide the best protection against water related damages, this type of wax is best recommended for brand new cars since the finish is still in great condition
    Collinite 845
    Collinite 915
    Mothers Step 3
    Megs Step 3
    TW Platinum Ultra Gloss
    Megs Gold Class
    Cleaner Sealants - is basically like cleaner waxes but instead of leaving a layer of wax they leave a layer of super durable synthetic polymers, cleaner sealants are best known for their ease of use and it best when topped with a pure sealant after for maximum bonding capability
    Carlack Nano Systematic Care
    Pure Sealants - are super durable synthetic polymers that bond to the paint, they provide a little less protection as compared to carnauba waxes in terms of water related problems but outlast and out protect carnauba waxes in terms of other protection like against chemicals, detergents, salt, bugs, bird droppings and a whole lot more, sealants are very easy to apply and in most cases easy to remove, they require 24 hours cure time to properly dry without causing any hazing problems, pure sealants are also most recommended for brand new cars to lock in and maintain the depth and the mirror like shine of brand new cars
    Carlack Long Life Sealant
    Mothers FX Synwax
    Hybrid - are a combination of natural waxes and sealants
    Megs NXT
    Megs Gold Class Carnauba Plus
    Mothers Reflections
    Eagle One
    For the ultimate shine and protection try Carlack Long Life Sealant topped with Collinite 915
    Hope this helps, sorry for the late reply, was prepping up for MIAS
