Page 62 of 296 FirstFirst ... 125258596061626364656672112162 ... LastLast
Results 1,221 to 1,240 of 5910
    Jun 2005
    #1221
    dehadista, just to be sure, what do you advice then as my step 1 - a mild polish such as speed glaze or a cleaner wax such as megs 66?
    by the way, i will be going to simex this weekend. malapit lang kasi simex sa amin. baka meron kayong pabibili from there, i can get some for you guys....just a simple gesture in return for all your help. i can meet you then dito sa the fort where i work.
    #1222
    basically, #66 is a strong cleaner wax. all-in-one (cleans, polishes and seals) 'to so this is different from speed glaze which, as a mild polish, needs a wax to lock in the look. (but the results produced from this especially with a machine are great!)
    Mar 2004
    #1223
    Quote Originally Posted by stubby
    Pa-report na lang ng mga stuff na makita mo doon. :-)
    BTW, if you don't mind me asking, where in The Fort do you work?
    #1224
    don't confuse #66 Quick Detailer (this is in liquid form) with the regular spray / spritz QD (Quik Detailer)
    Jun 2005
    #1225
    dehadista, i understand the difference between the two...thanks to this thread. what would you recommend between the two? im inclined to get the cleaner wax kasi meron na akong moms step 1. wala pa akong all in one eh. what do you think?
    ess, at the energy center near speedzone
    Feb 2005
    #1226
    ....sir, please post na din po price of megs 66 (or #66 Quick Detailer.) do you have contact # of simex? TIA
    Jun 2005
    #1227
    e chen, as per their price list, megs 66 (code M-6601) is p2440 per gallon. tel # of simex is 436-8361. laking mura kasi pag per gallon ang bili. tanong ko lang eh ok kaya shelf life nito kasi matatagalan talaga bago maubos.
    Aug 2005
    #1228
    Peeps, I found these articles about Removing swirl marks & water spots and Polishing. Will appreciate your own inputs on the matter.
    #1229
    AFAIK, that site is run by the wife of Mike Philips, detailing guru ng Megs. those are great articles BTW.
    stubby: if so, #66 ka na lang.
    afterwards, if you want, you can play with Speed Glaze / DACP. sarap isabay with the Menzerna line. hehehe
    Mar 2004
    #1230
    On most occassions (and due to time constraints), #66 or ColorX + any LSP works well for me.
    Feb 2005
    #1231
    thanks stubby. good luck on your next project!
  12. #1232
    I think you can buy Megs # 66 in repackaged bottles, its more practical, I don't know how long it will take to finish a whole gallon of polisher/wax unless you do this for a living
    #1233
    Unless you can finish up the gallon fast, I dont recommend getting a gallon as madaling maghiwalay yung product and if the mixture is incorrect, di na sya pwede gamitin.
    To Stubby: I believe may review ng Bosch sa PAD.
    Jun 2005
    #1234
    megs 66 it is then. i planned on getting a gallon kasi mas tipid nga, kaso as theveed said kung naghihiwalay pala eh di hindi rin pala pwede for the long run. i guess its best to check out those in repackaged bottles na lang, but im sure it will cost a little more.
    tanong ko lang po, which has better cleaning properties, megs 66 or moms cleaner wax? coz i plan to top which ever is better between the two with rainhop habang tag-ulan.
    btw, rainhop really beads and protects the surface well! 2 days after i applied rainhop, i gave my car a light water shower kasi may dust and dirt accumulation. after the hosedown, nakita ko na parang nakalutang yung water droplets sa surface! then when i wiped them droplets off, konting hawi lang nung microtex chamois tuyo na agad! will definitely be using this habang tag-ulan!
    theveed, i knew of the bosch GEX150AC thru PAD. there's this topic re a review on this tool using DACP. ganda naman daw gimitin according to the user.
    ess, glad to be of help!
    #1235
    66 no doubt
    Jun 2005
    #1236
    noted po. thanks theveed. question olet po....when applying megs 66 with an ROP, do i do it like irmscher did in his PAD bosch review using DACP?
    also, baka merong nagbebenta ng CCD...really need one!
    Feb 2005
    #1237
    still have one pero di ko mahanap yung bag... sealed pa ito kaso wala lang yung bag na kasama nito
    #1238
    pretty much, yes.
    btw, the microtex elite (waffle weave) will be out by the end of the month
    #1239
    alright! how about the bonnets 'veed?
  20. #1240
    Quote Originally Posted by theveed
    Thats what am waiting for...
