Results 451 to 460 of 5910
June 9th, 2005 09:35 PM #451
holding it comes naturally. just settle with a solid base and make sure you've got a good grip on it.
June 9th, 2005 10:02 PM #452
ILD: Thanks! I'll try to contact fineline!
Dehadista: Thanks din! Will consider Dewalt and Bosch!
I will update you guys on what I'm getting!
June 9th, 2005 11:18 PM #453
sa akin isang speed lang ang meron kaya medyo mahirap/takot ako gamitin..
June 10th, 2005 01:06 AM #454
Might consider getting one of 'em Rotaries next year...
Question lang fellow detailers, do you find your self at night under a light source looking at your car's hood at an angle, searching for swirlmarks? :lol: feeling ko na wwierdohan na sakin mga kapitbahay ko hehehe I always do that when I get home or after I wash my car. Speaking of swirls, may mga swirls na rin oto ko hehehe di talaga maiwasan
June 10th, 2005 01:10 AM #455
Originally Posted by zechs
for all intents and purposes, maybe you can at least use that for wax application and removal. that by itself should speed up your detailing sessions.also, you're gonna have even-coat applications too which means better results as compared to detailing by hand.
June 10th, 2005 01:15 AM #456
dehadista: what pad do you use for removal? the freebies that came with the B & D where virtually useless...
June 10th, 2005 01:15 AM #457Question lang fellow detailers, do you find your self at night under a light source looking at your car's hood at an angle, searching for swirlmarks? feeling ko na wwierdohan na sakin mga kapitbahay ko hehehe I always do that when I get home or after I wash my car. Speaking of swirls, may mga swirls na rin oto ko hehehe di talaga maiwasan
I won't admit it to anyone in the household but from time to time, I go to the garage to check on my car and just admire the work I've done or look for swirls that I may have missed. hehehe..
that's the problem with swirls. even moreso on daily drivers. they'll always be there... that's why we're always out there maintaining that new car finish.
June 10th, 2005 01:19 AM #458
Originally Posted by ILuvDetailing
sometimes I find the Megs Finishing Pad to be too soft though...
June 10th, 2005 10:57 AM #459
kung saan-saan pa ako pumupwesto para makita yun swirls against the light. yun mga curved angles hirap i-check for swirls hehehe. But usually, my biggest concern is the hood
There is a cheaper alternative to the Makita, its a makita replica and the brand is Maxsell. Meron ito sa TV. It comes in 6 and 8 inch, personally I would recommend the 6 since its lighter(less stress on the arms) and its abit easier to manuvure on tight spots. Plus!!! The 6 inch pads are cheaper hehehe.
Mahirap nga yun rotary at first. I got holograms, small scratches(caused by the backing plate) on the paint but this happend while trying to do tight spots - advice : kung di kaya, wag mo na pilitin, do it by hand hehehe Best to do it at night under your garage with flourescent lights, kase kung under the sun di mo makikita masyado yun holograms and fine swirls.
June 10th, 2005 06:51 PM #460
dehadista,
not sure what speed eh..hehe but not THAT fast naman, but still kinda scary to use it..i think its a BOSCH ata..check ko pagkauwi ko
I think we can agree to disagree on this. But I'm going to nitpick the point about deionized...
Coolant...
