Page 289 of 296 FirstFirst ... 189239279285286287288289290291292293 ... LastLast
Results 5,761 to 5,780 of 5910
    Aug 2009
    #5761
    Quote Originally Posted by madkatz View Post
    *weszt: the only swirls that SRP can remove are the really REALLY fine ones, for the deeper ones you need to polish for that, M21 actually has some filling abilities for a sealant and is good at covering swirls for up to 3 to 4 washes
    I haven't tried SRP with m21 but they should be ok with each other since they are both polymer based, KAIO and SRP might have bonding issues because KAIO is acrylic based and SRP's cleaning properties might actually just remove KAIO and nullify its protection, KSG on the other hand might also have bonding issues because KSG is also acrylic based and usually the harder protection should go in first which means KSG first before SRP if we follow that rule but SRP might also remove KSG, as for KSG bonding over SRP it might bond but im putting my chances on KAIO and KSG and SRP and UGP since those products are really made to bond with their designated partners. m21 is a stand along sealant BTW thats why im quite confident it could bond over SRP
    mga bonding issue na to ah. polymer to polymer. make sense also...
    how do i improve the durabilty of the m21? do i need to apply paint cleaner? confused na ako...
    tama ba to...
    Paint cleaner muna bago ako mag AG SRP then wait to cure for 30mins then apply m21 then cure again for 8-10hrs or more then apply next gen 2.0? and pwede ko ba gamitin yung car pag kalagay ng m21?
    out of stock kasi yung paint cleaner ng megs dito.. ano maganda pamalit as paint cleaner? meron yung claykit clener wax kaso diba hindi yun paint cleaner. my wax yun so hindi ok pang cleaning...
    Jun 2010
    #5762
    mega detailing Sunday for me... clay - Step 1 - NanoGlos - 476 - tapos umulan..
    before rain...
    beading after rain
    then i put nanosliq this morning... hayop sa beading lalo!!! I left my car at my office's open parking area... ayun naulanan...
    I went home at midnight, drove at 80kph... pag uwi ko, almost dry na! just used plush MF to completely dry... halos moist lang ung MF! ayus! daig pa nung pagka-moist ng ultra plush when i apply nano-sliq!
    Aug 2009
    #5763
    tama ba to...
    my QD ako dito pwede ba yung pang clean?
    Aug 2009
    #5764
    Quote Originally Posted by Nik View Post
    mam, bakit po agad mag start ma deteriorate yung NXT sa first wash kung nakapatong sakanya yung durable na collinte?? kala ko ma proprotektahan ni collinite si NXT.. ano ho ma rerecomend nyong mabisang pre wax cleaner? kahit ho pure na cleaner lang kahit wala nang halong wax...
    hindi ba ho kaya tangalin ng clay yung mga tinatangal ng pre wax cleaner?
    salamat sa info mam ^_^
    if you have collinite on top of NXT then it should last longer, Moms and Megs Step 1 are both great pre-wax cleaners, Collinite liquid sapphite is also good just be sure to take the pure cleaner one, clay can also remove those contaminants that pre-wax cleaner can remove but the tricky thing is especially for beginners is when they leave clay residue behind, but once a person it taught how to clay properly claying should already be enough
    Aug 2009
    #5765
    Quote Originally Posted by weszt View Post
    tama ba to...
    Yes paint cleaner first then AG SRP and then wait for 1 hour then m21 and then 12 hours and then NXT, and yes you can use the car when you finish with m21, just be sure to wash it again before you apply NXT and just pray that it doesn't rain during the 12 hour curing time of m21, m21 actually cures a lot faster, KSG cures for 24 hours. if they don't have Megs cleaner wax then its ok, actually after using swirlX you could proceed to SRP already since swirlX can also be considered as a cleaner, and yeah claykit can be used to clean paint as well to make SRP and m21 bond properly, clays aren't paint cleaners but it does the same job of cleaner the paint, so if you already have a clay kit then you don't need a prewax cleaner, or if you've just finished with swirlX you could go directly to SRP
    Aug 2009
    #5766
    Quote Originally Posted by rico_g View Post
    before rain...
    beading after rain
    nice job!
    WOW those are really tight water beading, they already look like small bearings its so nice to look at, its really cute when you see beads that small and round and then drive around and just see them fly off the paint hehehe
    Jul 2010
    #5767
    ayun !! got it mam.. salamat madami.. ^_^
    question: 476s or 815(yung insulator wax)? ano po pinag ka iba? and ano mas maganda saknilang dalawa.. sa ibang thread kasi insulator wax gamit nila..
    Aug 2009
    #5768
    tama ba to...
    well even if you use a cleaning QD on your paint you still can't get it 100% clean so you're better off with a pre-wax cleaner or a clay bar, claybars a more expensive but its well worth it, prewax cleaners are really cheap actually mothers has one for less than 500 i think, if you're thinking about using a QD for cleaning the paint you're better off using 50:50 dilution of isopropyl alcohol to clean the paint, thats what we use to remove oils from polishes to check if the correction has been or just filled
    Jul 2010
    #5769
    guys tanong lang..O.A. na ba masyado kung ganto gagawin ko?
    1. Megs clay kit
    2. megs deep crystal system cleaner wax (pure cleaner ba ho to? hindi ba nag babawas clearcoat?)
    3. megs colorX (ano ba talaga ginagawa nito? bawas clearcoat?) eto sana para pang paganda ng paint .. parang salamin ulit at lumabas yung kulay talaga..
    4. m21 (eto sealant ko para mawala swirls)
    5. NXT 2.0 (sa looks para muka mirror)
    6. 476s (protection)
    san po dyan dapat ko tangalin na step? may mas mganda ba kesa sa mga product sa bawat step na plano ko? suggestions please.. salamat
    Aug 2009
    #5770
    *jmpet626: heres the link to my post
    http://www.autogeekonline.net/forum/...t-bonding.html
    i actually feel like i didn't get my answer regarding the topic but anyways, see we've just tested some glazes topped with KSG and we noticed that it does in a noticeable way affect the sealants durability, so i was asking for the good ones and i didn't quite get my answer but anyways, i found my answer from our mentor he recommended an acrylic glaze he said he'll ship over to us from the US its a purely acrylic glaze that makes KSG and polymers bond to it properly, its one of the few glazes that doesn't have any oils in it, but it costs a damn 150$ for 64oz but we're taking the bite since we can pay him later at September. and PB blackhole also works great on sealants so far, but we're still on the 6th week mark of checking its effect on KSG, i just hope it can last longer and not affect KSG at all so far all other glazes with KSG have already died down on beading and shine and right now only PB blackhole stands strong
    also regarding the scratches, remember the hoods you guys used to practice rotary buffing? i've already tried wet sanding the thing and buffing it out again but it still has swirls in it, and if you look close enough i think its like the panel has been paint and then swirled and then painted again with clear coat because no matter how many times we compound the panel the same scratches always appear, so right now we're ruling out surface defect it looks like a painting defect already i think the painter got lazy and just sprayed on some clear coat without properly checking if the surface was swirl free before wet sanding the panel and laying the CC
    Aug 2009
    #5771
    1. Megs clay kit
    i would say you're better off with this
    1. Megs clay kit
    2. megs deep crystal system cleaner wax (pure cleaner ba ho to? hindi ba nag babawas clearcoat?) - it does but its negligible, meaning it does not make any difference its that safe for the paint you can't actually consider it reducing the clear coat
    3. megs colorX (ano ba talaga ginagawa nito? bawas clearcoat?) eto sana para pang paganda ng paint .. parang salamin ulit at lumabas yung kulay talaga.. this is actually a cleaner wax with more aggressive abrasives so kinda stay away from this if you don't need it
    5. NXT 2.0 (sa looks para muka mirror) m21 is better at giving you that mirror look, NXT just fills better than m21
    you could even just do this
    1. clay kit
    2. megs step 2
    3. m21
    4. 476
    and you'll also get great results, no need to overkill the procedure, detailing has to be fun and a little easy so try to simplify the steps, its true that all those steps might lead to a better finish but some steps can be omitted and still produce great results, for me colorX and NXT can be omitted even step 1 and 2 if the paint is in great condition, but then again m21 is very expensive hehehe
    May 2008
    #5772
    Ma'am, just want to ask, do you spray anything on a heavily soiled vehicle before washing it with soap? Do you also sell that by tingi?
    #5773
    *Nikko
    Haha ok lang yun. Mas mabuti nga if you'll ask here directly. Mas marami sila alam kaysa sa akin lalo na si mam madkatz
    *madkatz
    Maam this sunday po next detailing EB? Haha yehey :rofl:
    Jun 2010
    #5774
    For most detailers here yes they use kerosene, i only know one detailer that really uses body solvents instead of kerosene and thats actually our mentor and he's an american, but even we use kerosene because its really cheaper and it does a nice job.
    You might also want to try "Bosny Car Cream", I use it myself..P100+ ang isang tub (about 9oz size)...it smells like kerosene but is probably formulated to be gentle on paint...Kulay black ang container niya na yellow ang pagkakasulat ng "Bosny"
    Jul 2010
    #5775
    1. clay kit
    2. megs step 2
    3. m21
    4. 476
    mam pano sa "looks" yung wetlook na sinasabi ng NXT.. kung aalisin ko si NXT. pano na kikintab yung auto. si m21 ba o si 476 ang mag papakintab?? ano po yung megs step2? yung dipcrystal system paint cleaner or yung system polish?? (ayaw ko po gumamit ng abrasive na products, kun gmadami na talaga swirls sa expert ko nalang papagawa)
    Jul 2010
    #5776
    *Nikko
    *madkatz
    nakaka addict dito.. ang nasa utak ko ngayon.. money money money !! i need money !! HAHAHA
    *tsikoters - may tanong ako mga nakikita ko dito na pinost na photos ng detailing kit nila ang daming ibaibang product same lang naman ginagawa.. like UC tapos may rubbing compound pa may scratchX pa o swirlX pa.. diba same lang naman sila na nag babawas ng clearcoat para kuminis ulit..bakit hindi nalang mag stick sa isa?
    sunday EB? nasas church ako nun sa 10th ave.
    Aug 2009
    #5777
    Quote Originally Posted by Reepicheep View Post
    i just spray and soak the vehicle with the same shampoo im going to use to actually soak and soften the soiled parts, that is if this for the regular carwash, if we're doing a complete detail and sealing procedure, we spray citrus or biodegreaser on the paint before i wash it and then kerosene and then citrus or biodegreaser again and then proceed to clay buff and all that stuff, sorry but we're still in the works of getting them at a cheaper price by bulk, even now the gallons we have are nearly done and we don't have any upcoming shipments of citrus degreasers
    Aug 2009
    #5778
    *Nikko
    *madkatz
    Hehe well i think my BF talked to PSI about it already and i think yeah its this sunday but better ask albert about it since he's the one that gives the go signal. oh yeah if ever you're coming could you bring the glass cleaner? one of our cars are suffering from roadfilm again
    Aug 2009
    #5779
    Quote Originally Posted by mf051404 View Post
    ok noted, i'll try to look for that and give it a shot thanks for that
    Aug 2009
    #5780
    NXT is good in terms of looks thats true but collinite 476 isn't that bad either, but if you'll be using m21 then this is definitely better at giving you that mirror shine, m21 is better for me at gloss and reflectivity, NXT at depth and warmth, but if you already have m21 then its already enough, you could still go for m21 NXT and then 476 but be sure to note the curing time for waxes, its the deep crystal polish, it has some abrasives but you couldn't actually consider it to reduce your clear coat, its very safe to use that even if you use it for the next 10 years you still have clear coat left, and using step 2 will increase the clarifty of your paint, hmmm why not try to bring it over and attend this sunday if PSI gives the final go signal?
