Ok yang sa AG mura kung dyan ka bibili. BTW meron ako sobrang 6.5 na CCS black, white, at Green hehehe
Mga Boss magandang umaga sa inyong lahat.
Sir wala pong curing time ang mga QD's and gloss enhancer like nano gloss. Pagapply then buff tpos pde na kagad 476. I think karamihan ng mga curing time is yung mga sealant and some glazes.
Idol PSI musta?
Mga boss nakita nyo nba ito http://www.autogeek.net/optimum-hyper-polish-spray.html
Optimum Hyper Polish Spray. Mukhang maganda at madali gamitin. Adjustment nung abrasiveness nya is depends sa pads na gagamitin mo. May video dyan sa link.
Ganda na naging result dun sa Honda na buff sa video.
Congratulations sa mga naka attend ng seminar.
Sana makasama next time.
*jmpet626-salamat dun sa binigay mo, hindi ko pa nagamit, wala ko magamit na spray bottle e.
repapips, ang dabest
1) use the clay (to remove any unwanted dirt in the surface, kung baga huhubaran mo.........note all other application done will be remove....so hubad talaga)
2) apply nano sliq (?) or maguire step2, or 3M hand glaze or yung ke master EDWIN na material (sowi master lam mo naman malilimutin ako)......this is to make the bond of the wax to be used stronger
3) apply 476.....(pag nagka pondo na ko fleet gagamitin ko bwahahahaha! )
basic pa po yan depends kung matutuwa ka na....sa pagtagal di na po tayo makukuntento dito....so tatakbo nanaman tayo ke MASTER para mag upgrade ng materials.......
NOTE: last monday lang po me nag start mag aral ng detailing
follow at your ouwn risk.....![]()
ayus lang idol...eto entay ko si AZZ......
based on the article "Optimum Hyper Polish Spray contains a combination of super micro abrasives (which cut through the entire buffing cycle) and diminishing abrasives (which break down under pressure over time). This combined technology allows Optimum Hyper Polish Spray to cut as long as necessary to remove blemishes while still finishing smooth and glossy. Amazing!"
so this would in a way eat up SMALL coat....thus attacking the paint when the top coat is gone.....thus making the paint really shine since it attacked the outer layer....(just like color X tama po ba?)...if used correctly then ok...but not BWAHAHAHAHA!!! para ka ng nag DC..... ayaw ninyo yun tipid.....
*PSI Idol actually nakalagay is super micro abbrasive means may abbrasive syempre kasi nga polish but very minimal sya. Like they advertise adjustment nung abbrasiveness nya is sa pads na gagamitin mo. Kung yung Yellow more aggresive sya, pero kung yung black less aggresive sya.
*jmpet626 main advantage is no splatter at ease of use and no marring din kasi nga spray sya sabi sa video. medyo mahal nga lang
Pero pansin ko lang sa mga optimum products maayos sila and built para sa mga bagong auto paint.
Meron din yata nito si boss Edwin, dko lang napansin nung lunes.
kung baga sa programming language eh C# makabago. hehehe bias eh no![]()
OIC.... kahit yung optimum naten meroon ba niyan?
ganyan talaga mayaman.......try naten gamit DC by hand diyan city mo hehehehe!sure kikintab yan will finish it by 476..... ang lalabas diyan parang semi change color.....di naman masyado halata since silver color oto mo hehehehe!! silver din naman yung bakal HEHEHEHE!
Gamit ko sa ONR ko distilled water pag QD. Nabasa ko sa autopia nagbago daw yung color ng ONR from blue to clear pag tap water. Pero kung clay lube lang tap water lang gamit ko
*SG: don't worry there's still a next time, imagine how i would feel since i wasn't there, whats worse was that the pictorial didn't push thru due to the hard rains, all the effort for nothing i should have sticked with the seminar instead. but yeah i heard it was a lot of fun
Hello, there's no curing time for QD's, but there is a curing time for Nano Glos which is the standard 4 to 8 hours for waxes, so 476 also has a curing time of 8 hours, sealants vary from 12 to 24 hours curing time
as for the hyper polish spray, we actually have one, and its not as aggressive as the Megs 83 DACP, actually all products namely compounds and polishes vary their cut depending on the pads that you use, but so far we would rate hyper polish as something like Mothers Power Polish in terms of removing swirls and probably like Speed Glaze in terms of buffing to a high gloss.
Well i would say Optimum products really saves you money because unlike megs that sort of dries up very fast, Optimum has a very very VERY long working period for their polishes and compounds, so that product you have on the pad really lasts a lot longer, but we're still comparing which one gives the best result, we're comparing the polish II and finish II VS 105 and 205, As for the spray type we like it since we think its really easy to use, we did a whole car with an average of 2 sprays per panel only and we barely even used any product at all, but yeah i would agree that its expensive since the same amount can get you a liter of 205 already
Yup i would agree on this, if you know someone coming over from the US you would save a lot of money by having them bring it over for you, whats expensive usually is the shipping to our country since a few bottles and pads already costed us 154$ thats why we just opted for our products to be shipped via sea through balikbayan boxes, but the problem with that is the taxes and the grease money you have to pay for. So its really gonna save you a lot if you have someone coming over, my suggestions for pads would be Megs 6 or 8 inch burgundy, yellow and black pads, LC Purple, Yellow, Orange, White, Black pads.
