Quote Originally Posted by madkatz View Post
Most probably you already removed the embedded minerals deposited by the water marks so yeah the next logical step would be to use ScratchX, i would recommend SwirlX if its not bad though because ScratchX is quite aggressive, its true that you would easily remove the marks and swirls with ScratchX but you also remove more clear coat in the process
thanks alot for the info's... pahabol, how about for the watermarks of the windshield? rubbing compound? thanks again...
