Quote Originally Posted by umi001 View Post
Between the claying and the chemical cleaners of KAIO, yes, you'd expect those yellow spots to be removed - unless you're talking about etching in the clear coat or, worse, clear coat failure, in which case, only polishing (for etching) or, unfortunately, a repaint (for clear coat failure) will work. It would help if you post a picture, so we can see what exactly you're referring to
parang nasa loob na siya ng clear coat sir. nadidismaya ako everytime i see those yellow spots or "dagta"
alright sir, tom i will post some pictures. thanks in advance.
