Page 18 of 71 FirstFirst ... 81415161718192021222868 ... LastLast
Results 341 to 360 of 1418
    #341
    Members,
    XPRICE 100MPG challenged see htp://auto.xprize.org/
    :lurk2:
    Jan 2003
    #342
    Has anyone seen the infomercial for Auto Cool? It is a small solar-powered device that you place along the top of your car's window as you roll it up. As positioned a small portion protrudes outside the car. The solar power activates a small fan that sucks out the inside heat so that your car's interior won't become hot as it sits under the sun.
    Assuming it works as advertised, I was just wondering about the feasibility of incorporating such a device in the PhUV. It retails for P1995 but looking at it, I would estimate production cost to be under P500.
    #343
    *hein
    err...
    first ever cartoon in full color and with realistic human characters.
    what i meant is he just asked bank companies if his project is worth millions and i didn't say that he loaned some money.
    anyways, that anecdote is relevant because "others" think we can't do it but we will do it anyway even with the presence of stat quo hiatus.
    *topic
    applying forced perspective
    i call this van "butanding". the grill and side mirrors resemble the shark and the lamps imply "hey i'm friendly ride with me". hmmm....
    #344
    this one i call "tamarawFX2". the windshield resembles the previous tamaraw but i added cooler lamp shape and applied the signature grill.
    Aug 2006
    #345
    updated ISUZU KC-20
    #346
    Quote Originally Posted by safeorigin View Post
    err...
    Of course the bank agreed with Disney that the Snow White project was worth millions. Bank of America gave him a $500,000 COLLATERAL-FREE loan on top of the $1 million already spent on the movie. If this is not a VOTE OF CONFIDENCE, I don't know what is.
    The bank officers were not stupid fools. They insisted on viewing the still unfinished Snow White movie- and agreed with Walt on the potential of this groundbreaking endeavor.
    The bankers were proven right. The movie grossed $8 million and the loan was eventually repaid.
    I wonder where you got your anecdote?
    Aug 2006
    #347
    Quote Originally Posted by hein View Post
    Don't get your hopes up. 30 years na behind tayo sa technology. Expect a modest AUV-type vehicle using a lot of off-the-shelf parts and a lot of flat panels.
    ako ..i know how to measure yung mga standard units like inches, meters, millimiters, kilogram, joules, kilo-ohms.......etc, etc.. but "years behind"? How do you measure that accurately?
    Alam ko hein, naiinip ka lang....the PhUV prototype models are already built and are probably being tested. Siguro nga yung FMC model ay the one on trial run sa EPZA. yun.go there, take a look at it.. para mawala yung bugnot mo. Yung Dreamco model...meron drowing ako dito na kamukha nun....hanapin mo na lang at para maging busy ka sa pag-babasa.
    Aug 2006
    #348
    Quote Originally Posted by architect View Post
    as standard equipment? built in na sa roof....that's a good idea. pero how much current would the fans require and how big would the solar panels be?
    Jan 2003
    #349
    The Auto Cool in the infomercial that I saw was a relatively small device. I believe it is about the size of a VHS tape. It is stand alone and does not connect to the car. Both the solar panel and the fan are also pretty small, too.
    As it has openings for the outgoing air flow, it can't be installed horizontally. It has to vertically positioned with the air opening facing the ground. So a more preferred location might be on the side just above the doors.
    Aug 2006
    #350
    if tha fans are small, the rate at which the amount of air it can suck out will also be small compared the the time it takes for that same volume to heat up inside the car.
    Jan 2003
    #351
    That is very true. That is why I said "if it works as advertised..."
    We can implement a row of these devices on both sides of the PhUV to achieve the desired results, assuming of course it is feasible. Anyways, it is just a thought.
    #352
    wow... im interested to know more about this "Auto Cool".
    #353
    Quote Originally Posted by ISPRIKITIK View Post
    Members,
    Hi ISPRI.
    This looks more like an engineering challenge rather than styling.
    Dapat magkaroon din tayo ng propulsion guys sa tsikot.
    Meron kaya? Sana ...
    #354
    Hi architect. [hein, 'scuse lang ha? Back to topic muna kami. Thanks.]
    That system is a very cool and feasible idea, but its usefulness will only be to keep your car interiors cool while it is parked or stationary -- coz, if you have a bit of velocity, you won't need a mechanical ventilator, would you?
    Don't get me wrong. I like solar. I have a solar fan baseball cap. It really cools my face and is a small thing that made a big difference under the desert sun. :cool01: 2" diam, with a 4x6mm solar cell. Made in China. Mura lang. Visit http://www.sz-wholesale.com/shenzhen...-Fan-Cap_1.htm
    Overall, the best idea would still be to use solar cells to recharge your batteries -- ie, when the time arrives when they can generate enough amperage to drive an ACU, and the cost is no longer prohibitive. I'm dreaming of the day when all top surfaces of tropical cars will be an integrated photovoltaic array. Summa ecologica!
    Sourcing amorphous silicon solar cells is not difficult. So, why spend $15 for the device when with a bit of research and sourcing when we can design our own system and incorporate it to serve PhUV requirements? Initially, the solar cells have to be inside the car, 'coz you never know how the weather, cargo and people will beat on exterior surfaces of a moving vehicle. In the Philippines, the last place to put a photovoltaic array is the roof, and don't even think of the hood.
    :idea: If we just make sure there's a good enough rake, then solar cell panels can replace the usual windshield sunscreens. Alternatively, they can be mounted on the visors. Just flip'em down as you park outdoors - no switches needed. We might also need an optimum ceiling cavity to function as a duct.
    BTW, there are Filipino consultants and resources on photovoltaic systems: http://energy.sourceguides.com/busin...lippines.shtml
    More info:
    http://en.wikipedia.org/wiki/Solar_cell
    http://www.solarbuzz.com/Technologies.htm
    The biggest mfr in China is http://www.suntech-power.cn/
    Jan 2003
    #355
    * Drey,
    I saw the infomercial in one of the cable channels. I think the company is value vision (www.valuevision.ph) but when I went to their site I couldn't find the product.
    Jan 2003
    #356
    *dprox,
    Yes I am very well aware of the limitations of the Auto Cool. It is primarily for cars parked under the sun. (Especially these days. )
    As for solar powered cells for A/C - I am not sure if the technology is already advanced enough at this time to make it affordable or feasible, especially given our project objectives.
    But as you mentioned there are other ways of implementing solar technology to help cool the PhUV, why not? Maybe we can get some of the guys with the expertise to help us on this.
    #357
    Quote Originally Posted by OyiL View Post
    If you can't build a car to 1970's standards then you are 30 years behind. Simple as that.
    State of the Art Technology during the 1970's
    Oyil, kung FMC lang ang gumawa, never mind na lang. I have seen their products. Their workmanship is SHODDY, to say the least. Parang gawang latero. They are not a good representative of quality manufacturing.
    Aug 2004
    #358
    The thing is... we can. A 1970's Porsche has the structural rigidity of a Coke can, and the engine isn't that complicated. Handling-wise? There's a reason they call 911's widow-makers.
    And this isn't furthering this discussion any further. All the naysaying in the world won't do anything, and while the ideas put forth in this thread might come to nothing, it's worth saying that somebody actually tried.
    Aug 2006
    #359
    design and buid....to current standards...kaya. pera lang katapat nyan.
    FMC ang assembler ng Ford, Mazda, Hyundai, Fiat dati. to standards set by each brand. bad ba yun? if yuo just "saw" their products, e di visual test lang yung basehan mo..standard mo pa ang ginamit mo
    #360
    what? assembler ng B220 Pick-up ay FMC? tibay ahh...
Tsikot.ph PHUV Prototype
