Results 21 to 30 of 200
Threaded View
September 18th, 2009 08:16 AM #1
"[using] Mr. Singh's invention, the yearly national fuel savings would equal the amount of oil America imports from the Persian Gulf."
We are witnessing the culmination of resource depletions of every commodity and source on Earth on a massive scale along with senseless " Burning up of Oxygen " all over to keep us mobile, active & warm. At this point of time my Groovy technology is the only affordable solution as " New or Retrofits " that has emerged over time, regardless of some people's personal issues and their scientific merits to disprove it. Proof just keeps rolling in all the time. How many independent results equal positive findings ? When does the World take notice and see for ' Themselves ' just how good and simple the Grooves are ? At this point of time We do offer definitive solutions to bring down Global Warming & CO2 releases ! As none seem to be worried or effected by such issues? We are sure you will find the same " changes " that others have found after grooving .. Increased Torque, Increased Low-End Power and Overall Fuel Savings with Lower Emissions, resulting in much cleaner engines with lower operating temperatures and the capacity for unusually efficient engine " Tune Ups " without the dreaded " Knock or Ping " ! Some call this movement ~" A Single Straw Revolution " ! With a hope to bring about some positive changes around us and the way we drive into the Future . . . . .
Until viable alternative Fuels & Energy sources are Discovered or Invented, we will have to deal with " Air Breathing " Internal Combustion Engines burning up Petroleum products along with 15 POUNDS of AIR for every pound of fuel used up. Even IF advancements such as Bio-Fuels & Hydrogen Gas did come in to replace Oil we would still need plenty of Air to Oxidize all this fuel into Power !! Millions of drivers will not be able to afford new vehicles, even with ZERO percent financing. For the moment, large scale improvements in Engine Efficiency out of existing engines is most essential for our long term economic independence and social well being. Or Else ?? It is a real" Up - Hill Task " for most of us !
Read on ! Squish, Squash & finally Squashed ! ! !
US Patent 6237579 is applicable to any 2 or 4 cycle internal combustion engines featuring " Squish or Quench " concepts. The placement of one or more grooves or channels or passages in the squish area as shown & described in the first page of my US Patent 6237579 results in "Accelerated Laminar Total Clean Burn Combustion " out of any fuel ? Meaning to say, this simple but radical design change to squish areas & configurations enhances progressive turbulence in the charge close to the skin of the combustion chamber and further directs the (added) turbulence towards the igniter followed by multiple flame front propagation thus resulting in a radical change to " In-cylinder Combustion ". This technology is as radical a change to engine design as it was with the introduction of the ' quench ' concepts by Sir Harry Ricardo almost 80 + years ago. ALTCBC improves " Torque & Power " through the entire operating range with lesser amounts of fuel. This simple design change "opens up" the combustion chamber to activity. Hy-Brids can now benefit from enormous low-end torque produced out of smaller displacement engines to pull away with ease. Simplicity in design is the key to success in keeping down costs and pays for itself on the long run in a big way !
After this simple design change ~ Obsolete Side Valve Engines which feature large quench areas have shown reductions of up to 42.5 % in fuel consumption ( BSFC) when fully loaded at 2000 rpm on the dyno further producing more torque & power at lower operating temperatures in comparison to a stock engine. ( ARAI Test Results )
If the fuel inputs had dropped that drastically - What do you think the outcomes of " CO2 & Emissions " ~ Could or Would be ~ Out of grooved engines ? And the impact all this will have on " Carbon Credit " ...... and its earnings in the future ?
"Remember the most important factor in increasing engine performance and efficiency is to create " maximum turbulence " in the compression chamber."--Engine Legend Pat Goodman
This simple cost effective design change has the same dramatic effects on dual-fuel applications too & can accept much higher compression ratios on standard gas with out the interference of knock or pri-ignition. This design change requires minute in-puts to optimize the size & location of the grooves along with compatible compression ratios to optimize existing 2 or 3 or 4 & 5 valve combustion chamber designs. These changes are close to ' Zero cost inputs ' when it comes to mass scale production - Costing almost " Nil " as additional costs. The only other costs to be considered are " Licensing & Royalties " for the use of IPR.?
Lots of debates are on to figure out how this design could be achieving these advantages over normal squish & quench concepts. Lets leave the ' Indepth Study ' to the learned & see if they can improve upon it any further ? While this design is ready for implementation & is sure to make a Big Big difference to the Motoring World in the form of fuel savings considering the Cost of Crude Oils going past $ 100+ along-with the Effects of Global Warming taking over in a Big way ? Effecting all of us & the rest on the Planet too ! Some call it ~ " The Dimming Sun " ! ? ! ( Check it out on the net, it is for real ! ) A lot more Surprises are awaited in time to come . . . ? For Starters ~ There is three times more frozen CO2 hidden beneath the melting glaciers & sheets of age old ice waiting to surface up ..... This will bring about some sudden changes in the Poles ?
As a reminder - This design literally " Spells & Achieves "~ " More out of Less " involving the least inputs into existing engine designs.
We believe ~ " A Stitch In Time, Can Save Nine & More " ?
What Good Are " Discoveries & Inventions " ~ If They Are Not Put To Use ?
" The Answer My Friend . . . Is Blowing In The Wind ...... !!! " The essence of life called “Crude Oils“ soaring past $ 100 + mark has dampened the Global Spirit of well being. Most average motorists are in a dizzy of what awaits them as ‘ Future Shock ‘ ! While the Automobile Industry fully anticipating these hikes are going " Full Steam Ahead " stamping out Millions of ‘ Wonder Machines ‘ of every conceivable shape and size to promote & pacify the needs of personalized transportation like never before. All this hyper-activity has led to full house parking lots sending most of us on merry go-rounds like never before ? To add to all this, the existing " ON THE RUN " One Billion + I C Engines ticking away Globally are pushing the demands for Fuel & Oil beyond the reach of supply making Crude Oils even more expensive than the automobile itself ?
' How’s that ' for an equation ? Global Oil Sales each year are exceeding $1500 + Billion mark with Exxon Mobil alone showing a full year revenue of $ 371 + Billion. Sooner then later all this Oil is sure to burn up & turn into " Smoke & CO2 " and hang in the air for a while ?
Did you know One Gallon Of Fuel burns up enough AIR to let out almost 20 Lbs of CO2 back into the air from the tail pipe ?
Did you know One Litre of Petrol burns up enough Air to produce almost 2.5 Kgs of CO2 out of in-cylinder combustion !
- continue on next page -
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
