Your kidding right, Has this not been debunked to death. Let me through out something for you. Since I have actually done this for a few of my buddies who just happen to be jeepney drivers. When I get board on vacation in Angeles I also tinker. And being a water injection Guru I know my stuff.
Anyways you about half way right on your statement.
These Hydrogen on demand kits do not produce enough gas to make a dent in performance or fuel economy. And of course water injection will work on it because it works well on any diesel or turbo diesel to help burn unburnt diesel and improve combustion especially if you mix in alcohol, that's been proven beyond a shadow of a doubt for years.
If your guys really wanted some better mileage and no black smoke around a 5% gain in horse power over your power band on the cheap. All you need is.
1. washer fluid bottle with pump.
2. Hose
3. Misting nozzle around .5gph to 1gph
4. Misc fittings and electrical connectors
5. Micro switch to activate via the gas pedal
6. water/alcohol 70%/30% mix you can vary the mix even 10% alcohol will be more effective than a HHO device putting out 1 liter per minute.
7. Mount the nozzle just before the throttle body/intake manifold.
Look you just made a water injection system that actual will change the performance of the vehicle and actually lower emissions.
Feel free to try it if you don't believe it but that's a 100% Guarantee it will outperform that hydrogen kit in fuel economy, hp increase, and emission reductions.
By the way all these you tube video's prove zero on how effective any of these system are. When they can produce 50 liters a minute of hydrogen then they will be worth something but that's not going to happen on a 12v battery.
Now I have just giving you a option that actually works and should cost the average Jeepney driver less than 700P. He could run pure water and still outperform a HHO kit in every way. Plus no more smoke belching even at full throttle and a full load of passengers. Can HHO do that? Plus it will remove all the carbon build up out of the engine making it run much smoother and also furthering better fuel economy by keeping the intake, valves and combustion chambers clear of carbon/soote buildup.
Sure would like to see you r water injectiongadget. Where can I get to look at it?
