Originally Posted by
dvldoc
If your guys really wanted some better mileage and no black smoke around a 5% gain in horse power over your power band on the cheap. All you need is.
1. washer fluid bottle with pump.
2. Hose
3. Misting nozzle around .5gph to 1gph
4. Misc fittings and electrical connectors
5. Micro switch to activate via the gas pedal
6. water/alcohol 70%/30% mix you can vary the mix even 10% alcohol will be more effective than a HHO device putting out 1 liter per minute.
7. Mount the nozzle just before the throttle body/intake manifold.
Look you just made a water injection system that actual will change the performance of the vehicle and actually lower emissions.
Feel free to try it if you don't believe it but that's a 100% Guarantee it will outperform that hydrogen kit in fuel economy, hp increase, and emission reductions.
Now I have just giving you a option that actually works and should cost the average Jeepney driver less than 700P. He could run pure water and still outperform a HHO kit in every way. Plus no more smoke belching even at full throttle and a full load of passengers. Can HHO do that? Plus it will remove all the carbon build up out of the engine making it run much smoother and also furthering better fuel economy by keeping the intake, valves and combustion chambers clear of carbon/soot buildup.
