Page 6 of 6 FirstFirst ... 23456
Results 101 to 105 of 105
    Jan 2008
    #101
    Oyil mentioned that he was looking for a free CFD software and since I stumbled upon a couple of OSS I just thought of sharing it in this forum in case someone needs it. Most of them are for the Linux OS although some of them also support Windows. Try nyo na lang download in case the need arises. Maybe you can give a copy to DLSU Engineering faculty so the students can have access to these software tools as well. Everybody knows that the cost of commercial CAE software is quite prohibitive even for most academic institutions. Since the source code is freely available maybe the students and/or faculty themselves can improve upon it to suit their needs. They may be lacking in certain features vs commercial software but I think they are adequate enough for most basic research and dev't. applications/problems. Here are the links;
    CALCULIX
    - A Free 3D Structural Finite Element Analysis Software
    http://www.calculix.de/
    OpenFlower - Open Source CFD Solver written in C++
    http://openflower.sourceforge.net/whatis.html
    CAELinux 2008 - Computer Aided Engineering Software for Linux
    http://www.caelinux.com/CMS/
    OpenFOAM - Open Source CFD Toolbox for Simulations
    http://www.opencfd.co.uk/openfoam/#openfoam
    More Open Source Science and Engineering Software
    http://www.openscience.org/links/
    Jun 2005
    #102
    Quote Originally Posted by TambayBlues View Post
    ENGINEERING SOFTWARE COLLECTION VOLUME 6 FLUENT FOR THE AUTOMOTIVES
    FLUENT V 6.2 Flow Modeling Solutions for the Automotive Industry | LATEST RELEASE
    WINDOWS OS | ENGLISH |SIZE 600 MB APP | SOFT + DOC FULL| CAE SOFTWARE
    Fluent's CFD software products enable you to create virtual flow models within your computer quickly and effectively to quantify, visualize and optimize automotive designs early in the design process. The insight and efficiency that you will gain from using FLUENT will result in better designs in shorter cycles. FLUENT meets all of your automotive CFD needs, from component-level to full vehicle analyses. The unprecedented array of robust and accurate models permits for the simulation of the widest possible range of automotive CFD applications in the industry, including aerodynamics and thermal management, climate control, engine modeling, exhaust aftertreatment, acoustics, multiphase and multiphysics applications.
    Our software couples to industry-leading PLM, CAD and CAE software to ensure integration into your design process to provide the best simulation solutions quickly. We offer a full range of products and services including highly automated flow modeling tools that allow design and process engineers to perform flow and heat transfer calculations. We continually help automotive companies realize the benefits of CFD, aiding in both its initial deployment as well as the continued application to the overall design process.
    Let us show you how FLUENT can reduce your product development and manufacturing costs and enhance your return on investment.
    FLUENT is a VERY EXPENSIVE program. it's like a couple tens of thousands dollar for each license.... a university would probably spend 50-70 k Euros a year for 3 dozen licenses...
    Sep 2008
    #103
    Last September 2008, a series of forum on e-jeepneys and other locally fabricated electric vehicles were conducted in DLSU-D.
    Students were happy to see alot of new developments especially at the local assembly scene.
    Most students were surprised to see the MVPMAP-made e-jeepney...because they previously thought that we are not capable of producing an electric vehicle..
    Jan 2008
    #104
    Another good technology to learn is DFM or Design for Manufacturability, Concurrent Engineering etc. Here's several examples of real world case studies in MetalCasting Design or Design for Castability that you guys can download for anyone interested to further their research on the best practices done in automotive manufacturing.
    Chevrolet Corvette Brake Pedal
    http://**********.com/files/14889203...rake_Pedal.pdf
    Landing Gear Uplock Support for a Boeing 767
    http://**********.com/files/14890188...Boeing_767.pdf
    GM Aluminum Cylinder Blocks for Trucks and SUV Engines
    http://**********.com/files/14889240...UV_Engines.pdf
    Steel Plates in Oil Rig Blowout Preventer Valves
    http://**********.com/files/14892228...ter_Valves.pdf
    Drive Wheel for the Tracks on a Compact Utility Loader
    http://**********.com/files/14889220...ity_Loader.pdf
    Intermediate Lever Arm in the BMW Engine Valve Train
    http://**********.com/files/14889257...alve_Train.pdf
    Internal Interface Frame for LCD Digital Projector
    http://**********.com/files/14891912..._Projector.pdf
    Rotor Disc Casting for the Traction Motor in a Diesel Locomotive
    http://**********.com/files/14892915...Locomotive.pdf
    The Axle Housing for a Skid-Steer Loader
    http://**********.com/files/14889273...r%20Loader.pdf
    Housing for a Thermoelectric Fan
    http://**********.com/files/14890524...ectric_Fan.pdf
    Float Wall Panels for a Jet Engine Combustor
    http://**********.com/files/14892416..._Combustor.pdf
    The Ice Cleat on the M1-Abrams Tank
    http://**********.com/files/14890299...brams_Tank.pdf
    The One Person Hitch Housing for the 2.5 and 5 Ton Trucks
    http://**********.com/files/148893110
    Crossbleed Valve for the F-5 Jet Fighter
    http://**********.com/files/14890742...et_Fighter.pdf
    Transmission Case for the Advanced Amphibious Assault Vehicle
    http://**********.com/files/148901327
    Mercury Universal Joint Coupler for Marine Inboard-Outboard Engine
    http://**********.com/files/14891737...ard_Engine.pdf
    Jun 2007
    #105
    Manila Standard
    July 6, 2009
    [SIZE=4]Makers of e-vehicle parts seek incentives[/SIZE]
    By Elaine R. Alanguilan
    VEHICLE parts makers assembling electric jeepneys are seeking government incentives to make more of them, an official said over the weekend.
    “[They] want to avail [themselves] of incentives under the [Board of Investments’] Investment Priorities Plan,” Trade Undersecretary Elmer Hernan-dez said.
    The Motor Vehicle Parts Manufacturers Association of the Philippines was the first to make electric jeepneys or e-jeepneys. It has been producing five to 10 units a month since late last year through PhuV Inc., its business unit.
    PhuV president Ferdinand Raquel Santos says his group plans to mass-produce the e-jeepney and e-tricycle as a result of the warm public response to them.
    “The truth is, our orders and inquiries so far are for large school campuses, resorts, golf and country clubs, villages, farm lands, theme parks, malls and even for mobile ads purposes,” he said.
    “But we will [give priority to local government units] as we want to disperse the technology to the countryside as well.”
    [SIZE=4]De La Salle University-Dasmariñas also ordered one unit last year, said Rommel Juan, an officer of the parts producers association. [/SIZE]
    The e-jeepney technology is a tested vehicle abroad and is said to be very popular in China, one of the more advanced countries in electric vehicle development.
    The local e-jeepneys now ply select routes within the Makati commercial business district for free. Once fully integrated with the transport system, commuters will pay the same fare as they pay for riding conventional jeepneys.
    Yes..
DLSU-D Symposium on Phil Utilty Vehicle(s)
